Need Heads...recommendations.
I am going to be replacing my stock heads to gain some power and loose some weight. I currently have som old cast heads with machined 64cc chambers and oversized valves installed. I believe my sig has all of my engine info.
I am looking for the best head that I will be able to use and keep my camaro a street car with good potential at the track. What does everyone have, recommend? Money isn't really an issue.
Car: 99 Formula
Axle/Gears: 342
Since money doesn't matter, I'm sure most will say get some AFRs. Do a search on here, by far the most popular.
I just ordered some Pro Lightnings 2.08/1.6 64cc 200cc iron heads. Won't be on for a little while though. $675 for them.
Car: 1989 Iroc Z L98
Originally posted by iroc22
Pro Action heads are the best heads out there right now.
Car: 99 Formula
Axle/Gears: 342
Originally posted by Fast3rdGen
worl products sportsmanII heads are some really nice pieces as well but i haven't found them for the price that these guys are getting pro action heads. wish i had heard of these sooner
Originally posted by unknown_host
I thought that they used to be a division of air flow research but their quality control was so bad that AFR dropped them. That is what I have heard anyways ::shrugs:: For a budget aluminum head i think that the Trick flow 23* head is pretty damn hard to beat.
I never heard about them being owned by AFR. All I know is they're from Australia.
Originally posted by Cuno
So, are Pro Action and AFR the same heads?
alum. or iron? I am leaning towards the aluminum over iron. Are there any drawbacks to aluminum.
Also, what does everyone think about Edelbrock Performer RPM heads? Are the AFR and Pro Action that much better, what about the SWorld Products line?
I can not seem to find alot of info on the AFR and Pro Action heads, any useful links any one knows of?
Originally posted by Mark A Shields
Most steer clear of Edel heads.
Haven't heard many people who have tried the new E-Tec heads from Edelbrock. I'd like to hear about these heads from people who have tried them.
the e-tec heads dont impress me that much. their flow #'s are kinda lacking and the 200cc e-tecs require 1 3/4 headers, you cant run anything smaller on them.
Car: 99 Formula
Axle/Gears: 342
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Drawbacks? Don't let your girlfriend help you change spark plugs, start forcing those threads and you're screwed (no pun intended). The exhaust threads are heli-coiled though.
I've got Perf RPMs, I'm impressed with the quality and I could hardly get a set of iron heads finished to the state these are in for the price. Top quality machine work, S/S valves, screw in studs, guide plates etc. Just run 'em.
Compression shouldn't be a prob if I get the 64cc chambers as I should be getting 10-10.5 to 1 C.R.
After looking over their site, the AFR 195 heads are looking really nice. Looks like I'll have to take a 68cc chamber which will lower compression a little. I may add charger on top down the road so that would be ok.
Where did you buy yours from Mark? From AFR?
Car: 99 Formula
Axle/Gears: 342
oops, forgot they are not AFR. They are very simialar to the AFR heads. Main difference is that the AFR heads are aluminum which I really prefer. I can't seem to find a place to buy the AFR heads from though. I'll have to keep searching. Thanks for all of the very helpful info everyone.
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Cuno,
Go here: www.totalengineairflow.com and ask for Brian about the AFR's. It took about 3 weeks for me to recieve my 190's.
Car: 86 Firebird
Engine: 355 4 bbl
I can get behind AFR's philosophy regarding their cylinder heads; high-flowing heads with a relatively mild camshaft makes mounds of torque right across the rev range.
They've cranked out some really impressive dyno numbers using camshafts that a lot of street rodders would call 'tame'.
Throw the big cams away.
Since money is no object why don't you check out GM's splayed-valve heads (p/n 24502517). At about $1300 each (not including tax or shipping) they are pricey. The 45 cc combustion chamber presents a problem if you want to run those heads on the street, but they are definitely trick.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The Brodix Track 1 is another good head. With porting they are way over 300 cfm.
