Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
anyone changed their torque converter on a pretty much stock L98?
Old May 27, 2001 | 04:19 PM
whiterocz's Avatar
what stall speed did you go to and what kind of gains did you see/feel? how does it make your car feel faster?
Old May 27, 2001 | 09:24 PM
88 IROC BOB's Avatar
I've put in a Vigilante 2800 stall in a an otherwise stock (except for most boltons).
I've only been to the track once since its been in but my 60 fts went down to 1.79 (stock convertor was 1.95) and my ets were in the 13.90's (although we had a brutal headwind that day).
It's only slightly different on the street. Nothing that would bother you though. If you are going to do some drag racing with it you will definately want a t least drag radials.
With my stock convertor on street tires I never spun off the line. With this convertor in and drag radials sometimes traction is still an issue.
Bottom line-- this is a great mod although a little pricey its well worth it!
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old May 28, 2001 | 02:53 AM
Raymond 5.7 89 Formula's Avatar
I was under the impression that you would not want to change your converter in a stock car. What is the peak torque RPM for a car like mine? Would a stall speed around 2200 be better than stock for me?
SLP 1 5/8 Headers,ATR catback exhaust,SLP cold air box,Crane 1:6 roller rockers,Bosch plugs and MSD wires,MSD Coil,Fastchip,Borg Warner 9 bolt 3:27,Corvette Servo,ROH ZS 17X9.5 Goodyear GSC,s 275/40/17
[This message has been edited by Raymond 5.7 89 Formula (edited May 28, 2001).]
Old May 28, 2001 | 07:52 AM
purpleworm's Avatar
I put in a 2000 and it made all the differnce in the world. I only street race because there are no tracks around here but I noticed a huge difference. My car was put right into where it starts to turn on.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
One sweet sounding system
Old May 28, 2001 | 08:46 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
A convertor is one of the best mods to do to a stock motor. IMHO, a 2000 stall is a waste of time. Get at least a 2800 stall in a 10 inch converter.
Old May 30, 2001 | 03:09 AM
88IROCs's Avatar
The advertised peak torque on a L98 is 3200 rpm. For best acceleration, your converter should stall about 400 - 500 rpm short of peak torque. So a a true stall of 2800 rpm would be right on the money. However, if you can't swing the dough on a high stall converter, almost any aftermarket converter will be an improvement as the stock converter stalls at an absurdly low 1600 rpm. Any converter will multiply the input torque(sometimes as much as 3 times the input torque) until it reaches it's stall speed(hence the name "torque converter"). This is why auto tranny equipped cars launch so much harder than manuals(and at lower rpms to boot). But keep in mind that until the converter stalls, it is slipping and generating heat. The higher the stall speed, the more heat that is generated. So an upgrade to the tranny fluid cooling system should be figured into the cost of a new converter.
For a some well written articles on how torque converters work check out this site,... <a href="http://www.racer-x.f2s.com/">Garage</a>
Old May 30, 2001 | 08:27 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i chage the convertoer in my 91 rs and it made a huge difference in launching power in in my 305 tbi. i got one from SLP. that stalls abot 800 above stock . it works great.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
gwade12
Aug 8, 2015 08:17 AM
