Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Cam experience
Old Jun 30, 2001 | 11:36 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Cam experience
is there anybody out there running a comp cams XR269HR or XR276HR, Xtreme energy hydraulic roller in there 350? I want to know how you like it and if you know what kind of power it is making. Thanx
Old Jul 2, 2001 | 08:35 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I ran a Comp XE Hyd Roller custom grind 230/236@.050 .544/.555 112lsa ground 4 degs advance in my 383 up until this past spring. The cam worked very well! I had no problem passing emissions with it and the idle was very stable. One suggestion that I would make is to use the Comp 987-16 springs with any of their Hyd Roller cams due to the aggressive ramp. Also if it's in your budget, use Titanium retainers as well.
By the way, I am now using the Comp Extreme Mechanical Roller cam with some pretty impressive results so far.
D&Z Performance
"Putting Power to the Pavement"
[This message has been edited by HiTech5 (edited July 02, 2001).]
Jorlain
Oct 8, 2015 01:57 AM
Street Lethal
Sep 7, 2015 01:09 PM
dimented24x7
Sep 6, 2015 03:51 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
