Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Need quick answer using Hypertech gauge
Old Oct 13, 2000 | 01:36 PM
theformula's Avatar
Ok, first of all my throttle body and upper intake plenum are off the car. So I decided to install an AFPR. Well I checked the stock pressure setting and it was at 42psi. I did it with the ignition on/engine off like it said to do.
Did I get an accurate reading? I read somewhere that with some sort of "vacuum" hose disconnected or something that your PSI reading will differ. ???
anyone?
thanks
'92 Formula
305 TPI
Mods: SLP catback,SLP air foil,ported plenum,Crane AFPR,MSD6AL,homemade cold air,K&Ns,3:73s
Old Oct 15, 2000 | 08:49 PM
Stell1579's Avatar
on the regulator there is a fitting for a vacume hose that goes to the plenum. now with the engine running the vacume loweres th efuel pressure, as you open th ethrottle and the vacume gets lower the presure goes up. how you set the regulator is you set the max psi (disconnect the vacume fitting) now thats just about the psi of the fule when your engine will be at WOT now i would check the pressure with the engine running and the vacume line disconnected and plugged for the most acuracy. but for roundabout acurat readings just key in th eignition engine off will do
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch
And Always Trying To Go Faster
Bubbajones_ya
Jul 6, 2024 08:32 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
Glowsock
Sep 6, 2015 06:40 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
