More problems with Spohn Torque arm....
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by L98 Z28
Is there way to make it bend rather than flex up when its jacked up and having come back down?
Car: 1991 Camaro Z28
Engine: 350 L98
The loop option is down temporarily. I'm working on a new set up that will be adjustable side to side and up and down. Yes, it will cost more than $40.00 as it's much more involved. But if you want a loop that is adjustable for any type of application, this will be the ticket.
Golf clap sound.
Man I'm now sold on your tourqe arm steve.
Ok, we found an easy solution. Loops will be back up tonight. There's no need to go to a more expensive adjustment system.
We use a 5" i.d. tube for the loop. I put the loop in the press and "ovalized" it. The loop now has a 4.5" wide i.d. and a 5.5" high i.d.
This will give added height for lowered cars, and there's now way in hell the arm could ever touch the side of the loop now, no matter how low you are.
On with the show.......
Steve
Steve
Car: 1992 RS
Engine: 406 Stealth Ram
Originally posted by CHRISMAN2000
So now if you've lowered your car you don't have to "massage" the underbody.
Car: 86' Z28
Engine: 355
Steve
Steve
I'm too am glad you actually care about costomer complaints. The best products available are often times the ones that recieve the most amount of critisism. Knowing whats wrong with a product and fixing it is the best way to make a great product.
Eric
awesome thanks alot! jim3rdgen@yahoo.com
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
