Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
underdrive pullies
Old Aug 4, 2001 | 09:38 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
underdrive pullies
are underdrive pullies really woth the $70? do they make that big of a difference? i have heard conflicting stories like they drain too much power off your alternator and they make your car idle lower. i know march makes a 2 pully kit (crank and alternator). should i invest??
Old Aug 4, 2001 | 09:48 PM
JETHROIROC's Avatar
Try doing a search for "underdrive pullies" on the Tech/General Engine board. That should get you more info than you ever wanted to know.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Aug 5, 2001 | 01:12 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
A quick answer, no, not worth $70 on a basically stock engine. I felt no SOTP difference but it might add a few HP when your engine revs in the higher rpm's or when you have some good power.
89 IROC-To see mods go to: http://www.geocities.com/buckeyeroc
Old Aug 5, 2001 | 08:33 AM
FormulaKid's Avatar
Car: 1989 Firebird Formula
Underdrive pulleys are definatly a better choice to do after you have done some other mods like exhaust, heads, cam, porting, etc. Save them for last.
Old Aug 7, 2001 | 12:03 AM
Crushin91's Avatar
I have the 2 pulley setup from March. I noticed a little less drain from the A/C and some better pull at higher RPMs'. You do have to get the overdrive pulley for your alternator though!!
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
bryaniskoo
Oct 1, 2015 03:18 PM
italiano67
Sep 22, 2015 08:42 AM
Navy8125
Aug 22, 2015 07:13 PM
