Making the Air Cleaner work
I just bought an edelbrock universal air cleaner, it doesn't fit my quadrajet at all, and the screw isn't tall enough to even screw the aircleaner in, how'd you guys get it to fit? Also is that air cleaner that comes with the edelbrock air cleaner any good or should i go buy a K & N. Thanks so much
you have to go buy a new stud for the air cleaner at a hardware store and trim it down to size. I would go with the K&N filter.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
'86 IROC 5-speed
305 LG4
msd pro billet hei
'95 3.23 rearend
what do you mean by it wont fit at all?just the stud or is there another problem.It should fit.Mine lays on the water neck sensor but just barely,it also comes close to the distributor,but does fit fine.Be careful not to strip the threads down in the carb/tb essing with a new stud.
~mike~86 IROC-Z
~mike~86 IROC-Z
the air cleaner you bought is probably a drop base, which requires that you by a spacer in order for it to sit correctly on the carburator(with a q-jet or elctric choke AFB)
'86 IROC 5-speed
305 LG4
msd pro billet hei
'95 3.23 rearend
'86 IROC 5-speed
305 LG4
msd pro billet hei
'95 3.23 rearend
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
