Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
msd ignition? flowmaster 40 series? or headers?
Old 08-24-2001, 05:02 AM
speedfreaker's Avatar
i fell into some extra cash and im depating on gitting the msd ignition flowmaster 40 series mufflers or some headers what whould u chose to do to get the most power ?????
CHRIS
1983 firebird transam
Old 08-14-2002, 12:15 PM
Oscar's Avatar
start with the muffler.
Old 08-14-2002, 12:30 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Muffler or even a nice 3" cat back first..then headers.Until you get more mods on the motor don't worry about the MSD ignition boxes,just make sure you have good quality products in your stock ignition system.About the only thing in the ignition I would recommend upgrade (eventually) is to the MSD HEI coil,well worth the money.Do the exhaust first though.
Old 08-14-2002, 09:25 PM
RSCamaroGuy92's Avatar
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
I'ld save up the extra and buy the whole exhaust
Get the whole exhaust at once.
Think about it, when you just buy a muffler, you have to get the old on off, which usually requires cutting the d@mn thing apart. Then its a PITA to get back on the new muffler. Then you go and crimp the new muffler with the clamps, which makes it almost impossible to get back off and get the new exhaust pipe back on when you replace the whole thing.
Dynomax has a header y-pipe combo that you can get for $200. (2 1/2" pipe). A 2 1/2" intermediate pipe from Walker isn't more that $100. (assuming you junk the cat.)
and the 80 series Flowmaster should be less than $90. We are still under $400. and almost did the whole thing. Makes sense, eh?
All that you need to do then is salvage your old tail pipe or spend $50 and get 2 1/2" new ones.
This will liven up your car and make it sound D@mn good.
Now if you bear with me. This would be the most intelligent plan of attack to wake that car up after you save up money again.
Then your next plan of attack would be the Intake. (you freed-up your exhaust to let more air go through. So now your biggest restriction in power is how much air isn't making it into your exhaust.
This includes changing you stock air cleaner to open element or dual-snorkle type to let that intake get that extra air.
After that is done, the heads will be next in line.
then the throttle body itself, goto a 670holley or something compairing. Followed by a custom computer chip designed for your specifics.
last but not least, the ignition system.
Old 08-15-2002, 08:02 AM
Dragula's Avatar
buy a cat-back exhaust, then headers, then lots of other stuff before the ignition. You will see less of a gain with the ignition than anything else.
Old 08-15-2002, 09:04 AM
RS91's Avatar
Get the entire exhaust setup at one time to save you money and time.......
Old 08-18-2002, 09:43 PM
jfawcett10's Avatar
Car: 1987 Formula Firebird
Engine: 350carb
id go with dynomax superturbos, thats what a friend has and he VERY pleased with the sound and performance.
(i cant help you on this one too much though, i dont even got one!)
BRoss99
12-07-2020 06:50 PM
Navy8125
08-25-2015 08:25 PM
pgagnon42
08-24-2015 06:50 PM
theurge
08-21-2015 12:46 PM
tartagliaz28
08-15-2015 10:59 AM
Quick Reply: msd ignition? flowmaster 40 series? or headers?
