Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Accell runners and base
Old Sep 19, 2001 | 03:17 PM
evilho7810's Avatar
Let me say that these have to be one of the WORST fitting products i've ever seen. It seems that everytime I think i'm getting somewhere boom some other bull**** pops up. Do yourself a favor and have your mechanic install this pieces of **** for you.
Old Sep 19, 2001 | 10:39 PM
james_fearn's Avatar
ya, the fit is pretty bad. here is what I did over the summer and the problems I had with them.
https://www.thirdgen.org/messgboard/...ML/001775.html
What problems did you have?
James
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC/LCA/PR, GW "wonderbar"
Old Sep 20, 2001 | 04:08 PM
IROC&ROLL
Guest
Posts: n/a
Maybe they've changed in the 10 years since I bought mine, or maybe they are different... mine are Accel/Lingenfelter. The fit is great. The only drawback is the valve covers must be removed in order to get at the lower bolts.
Old Sep 22, 2001 | 03:14 PM
evilho7810's Avatar
Well I had to stud the manifold in the rear passenger side because the bolts that you have to torque down also hold the coil bracket (I have a 91 so my coil is separate). They could have machined the area flat but anyways it's pretty hard to explain without showing you. I had to drill the runners because the bolts weren't lining up right into the plenum. I had to grind some bolts heads to clear to runners. And I had to go on a mission to find some bolts to use on the bottom four runner bolts.
Old Sep 22, 2001 | 05:26 PM
I had to modify my bracket for the EGR solinoid, which needed to be flat. I also needed new bolts for the fuel rails so I could tighten them when the runners in place. I had to modify my AC compressor support bracket on the front driver side of the intake manifold. I had to modify a few bolts heads for the alternator bracket support. etc, etc, etc. That stuff takes some time....
James
Old Sep 22, 2001 | 08:01 PM
Dan87IROC-Z's Avatar
Yeah, I thought the base seated nicely on the block and heads, but my stock runners were a PITA to install, I accidently cross threaded one of the bolts, and the PCV port on the base didn't fit right with my hose fitting, so I had to get a new one of those, but other than that, I was pretty happy with it, it made a nice improvement in my car's performance.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Sep 28, 2001 | 08:06 PM
Tom Keliher's Avatar
I guess I must have been lucky, because mine fit easily.
Old Sep 28, 2001 | 11:45 PM
86 IROC's Avatar
I too had fitment problems. My plenum wouldn't seat. I ended up planing down each side of the plenum slightly to get it to fit. Before I did that, everytime I tried to seat the plenum - the damn gaskets squirmed out the bottom. And yes - I did have everthing else as loose as possible so that it would got together easier. It didn't work.
But, as we all know by now - 90% of the aftermarket parts we buy never fit as advertised. But, I guess that's what keeps it interesting.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
bjpotter
Oct 4, 2015 07:48 PM
Royal_Z
Sep 30, 2015 08:45 PM
