heads
heads
im biulding a street project its a 85 trans am the motor is a 383 13.5.1 comp ratio 650/655 lift lunati roller bore is 30 over the only prob im having is im not sure what set of afr heads to use if any one can post a set that might work plz do
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Yeah AFRs are lightyears ahead of the 'ol fuelies. Id consider some AFRs or maybe Brodix, they make decent large-port heads, although the AFRs probably outflow them.
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
ProTopline 220 or 200
Check there numbers compared to AFR, and is half the cost.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
