Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Engine swapping, need advise!
Old Oct 3, 2003 | 11:47 PM
Bird-dog's Avatar
Car: 5.7 TPI Astro Van, 91 GTA
Engine: 92 5.7 and 91 5.7, both modded for extra umph!
Transmission: 4L60 in both
I'm doing the unthinkable, and it's almost done, I have stuffed a 91 L98 TPI in my Astro Van, yeah, I know, guys V/8 these things on a daily basis, but I have yet to see one with the TPI.
Here's the problemo, I am wanting to **** can the smog equipment and also dump the A/C, the A/C is no sweat with the delete pulley, and the same for the smog pump. I need to know how bad my computer is going to freak out with out having the smog stuff plugged in and hooked up??????? I really don't want to keep the emissions, but I will if I can't get a top notch professional answer, Hurry Guys, I want to see this thing ripping tires off by Halloween! It's been a long dream and it's finally there!
Old Oct 4, 2003 | 03:12 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
a quick answer from a carb guy, if you are going to keep the TPI, you are going to have a chip burned that deletes the EGR!,AIR!, and smog stuff. if it is a stock setup, it may not miss the emissions stuff. might want to check on the TPI boards though.
Old Oct 4, 2003 | 11:10 AM
MdFormula350's Avatar
well first off awesome!! my mom has a astro van and on the internet i saw this site that put in tpi engine into them, its a pretty easy swap from what i have seen.
to stay on topic, i have deleted my cats, air pump, a/c, and didnt touch the computer and its running great.
so you should be fine.
f.y.i u dont really need the smog delete pulley, i just used a different routing and bigger belt.
Old Oct 5, 2003 | 01:10 AM
Bird-dog's Avatar
Engine swapping advise answered,Thanks!
Thanks to the guys that have replyed to my post, I'm deleting the bad and going for it! I'l sure be happy ripping around town in the new Fastro Van!
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
