Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
New Spohn Torque Arm
Old Nov 10, 2003 | 10:26 PM
SteveSpohn's Avatar
We just released a new torque arm. This unit is adjustable like all of our units, but it mounts in the factory location on the transmission into a supplied polyurethane bushing.
Part # 399 - $295.00
Details are here:
http://www.spohn.net/product.cfm?productid=1475
Thanks,
Steve
Old Nov 10, 2003 | 10:54 PM
25THRSS's Avatar
What is the advantage of using this over your standard torque arm which relocates the front mounting point?
Old Nov 10, 2003 | 10:55 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Mufflex LT ypipe clearance, less weight
Old Nov 11, 2003 | 12:28 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I'd love to have the chrome-moly one, but that's steep....I assume that's 125 over the 295 price listed?
Old Nov 11, 2003 | 12:41 AM
JMatlock88's Avatar
Car: 1991 Formula
That's correct. I bought a chromemoly one. My crossmember ta was about $600 shipped to my door having added several other options also. Price you pay for quality and for a true bolt-on!
more discussion here...
https://www.thirdgen.org/techbb2/sho...45#post1556245
Old Nov 11, 2003 | 09:10 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Can you setup this TA to have an integral Driveshaft Safety Loop? I've seen several guys who have modified their stock TA's to weld on a DSL. Would be neat if this one could have one bolted to it ... or welded to it. The TA and Driveshaft move together when the TA is mounted to the tranny so it should work AOK ... specially since tons of guys are doing it with their stock TAs.
Tim
Old Nov 11, 2003 | 11:56 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Mr. Spohn, would it be possible for you to make a bolt-on DS Loop for that new Torque arm? And if so, what would the price be?
Old Nov 11, 2003 | 04:10 PM
SteveSpohn's Avatar
This bolt in loop will work with the torque arm:
http://www.spohn.net/product.cfm?productid=1312
However, that loop will not clear a Mufflex y-pipe. We thought about putting a loop on this arm, it could be done, just welded right to the top tube of the arm just like we put on our rear loops.
However, my thinking was this. The limit of this arm is the transmission tailshaft and/or transmission torque arm mount. If either one of those lets go and the arm has a loop on it, it's gonna destroy the driveshaft.
Steve
Old Nov 11, 2003 | 04:47 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
steve, if you torque arm lets go, would the driveshaft even be a concern, i would imagain you would be going for quite the ride if you hit the brakes.
Old Nov 11, 2003 | 05:09 PM
SteveSpohn's Avatar
The torque arm won't let go, this thing is indestructable. However, the tranny tailshaft, tranny mount, and or stock TA mount could. The arm doesn't go down all that far under braking, it won't hit the ground. But under acceleration it'll slam into the floor, if there's a loop on it the shaft will be screwed.
If someone is willing to understand/accept that risk, I'll build one with a loop on it. Just call and ask for it.
Steve
Old Nov 11, 2003 | 06:00 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
See, that would be a concern that I would have. I have a six-speed AND longtube headers with the mufflex y-pipe. What kind of loop would you recommend for my setup?
Old Nov 11, 2003 | 08:19 PM
TRAXION's Avatar
Steve
Awesome. That's exactly what I was looking for. What's the extra cost?
Tim
Old Nov 11, 2003 | 08:36 PM
SteveSpohn's Avatar
$40.00 per loop (can get front and/or rear)
Old Nov 11, 2003 | 08:40 PM
SteveSpohn's Avatar
Your only option is a loop that bolts to the floor pan. I can get you the Lakewood loop designed for the thirdgen that bolts to the floor. I think it's $35.00.
Steve
Old Nov 12, 2003 | 03:49 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Mr. Spohn, you have mail.
Old Nov 12, 2003 | 07:49 PM
OMINOUS_87's Avatar
Did the this occur during product testing?
At what level would this occur?
Old Nov 12, 2003 | 09:34 PM
SteveSpohn's Avatar
This happens with the stock torque arm. The dyno shop near us has had at least a half dozen snapped tailshafts on the dyno. I would personally run a transmission mounted torque arm on a 12 second car. Once you hit 11's it's time to get it off the transmission. Of course most cars running faster then 12's have a tranny other then stock because of strength issues, so they can't use a tranny mounted arm anyway. The manual cars are the main victims of it, I haven't seen many automatic cars do it.
Steve
Old Nov 12, 2003 | 11:00 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Hey Steve,
I'll probably never take advantage of the strength of CrMo tubing on a car running a 700r4 in the 11s, right? What about weight savings though? Just trying to justify the extra $125.
Old Nov 13, 2003 | 07:54 AM
SteveSpohn's Avatar
The main advantage is double the strength, but it's about 4 lbs. weight savings.
Steve
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
Nick McCardle
Sep 10, 2015 08:36 PM
