Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Trickflow 23deg, ? flow numbers??
Old Nov 2, 2001 | 06:27 PM
craiger's Avatar
I order a set of AFR's and was given the wrong heads. Not sure if AFR can get me my heads in time. I must be finished with the project by December and AFR may not be able to get me a set before I need them. Does anyone know what the trickflow 23deg heads flow at .400 &.500? I am sick about this whole deal with the AFR's. I really wanted them and i may have been screwed Anyhow, Trickflows are in stock and I can have them at my door in a week. This project must be finished by December.
Old Nov 2, 2001 | 11:55 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Check out http://www.airflowresearch.com/Artic...e_archives.htm under flow to go, there you'll find some flow nbr's. I can recommend Canfield 195 cc heads www.canfieldheads.com they also is in the flow to go article.
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Nov 3, 2001 | 09:12 AM
Lounge Lizard 6's Avatar
Try this link from Trick Flow. It's in Adobe. Look under Airflow chart.
http://www.trickflow.com/media/pr/pdf/23degree.pdf
Mike
'90 IROC-Z , 5-speed, ZZ4, G1 Trick Flows
Moderator SEThirdgen
Old Nov 3, 2001 | 05:33 PM
spuge29's Avatar
the flow #' are as follows
int. exh.
.40 223.77 169.80
.50 245.00 187.60
87 IROC-Z
305 AUTO 2.73 OPEN REAR, T-TOPS, GUTTED AIRBOX, HOME MADE RAM AIR, AIRFOIL, UNDERDRIVE PULLEYS, ACCEL CAP & ROTOR, ACCEL COIL, TPIS WIRES, BOSCH PLATINUM PLUGS, JUST HIT 80,000 MILES
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
84redta
Sep 19, 2015 09:58 AM
Springster
Sep 13, 2015 01:38 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
