lonsal's nylon trunk motor guide inserts
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
if you have problems with you electric trunk motor not aligning all the time or if it rattles around and is in a general state of disrepair---
email this guy lonsal@home.com and he'll send you some replacement guides/sliders for the trunk motor. I just installed them and they fit perfectly and stopped a rattling problem I had.
good stuff.
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts, PST front end poly stuff, Earl's hyperflex brake lines SSM SFCs, Bilsteins very trick homemade ramair, Accel 300+ ignition system. Ported plenum, intake and heads with 1.94I valves.
Planning: Heddman 1-5/8 longtubes, NOS 150 plate, replace the "peanut"! and Eibach Sportlines.
check it out at:
http://www.geocities.com/transam617
good stuff.
check it out at:
James, Thanks for the compliments. I saw a niche and filled it. One of many I
intend to fill. I'm glad they worked well for you. Out of curiosity, what
combination of the guides did you use? I,O,I,O? Or some other combination? For those that haven't seen these yet, I make them so they can be adjusted to fit the manufacturing tolerances of the mating channel. GM does this by adding a raised nub that quickly wears down, leaving them to rattle and move around too much. Also their design is injection molded with the minimal amount of material possible. Mine are solid nylon, Machined to be a drop-in replacement and last a lot longer.
Thanks,
Lon Salgren
Top-Down Solutions
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Thanks,
Lon Salgren
Top-Down Solutions
90 RS Convertible
(626)369-0040
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
<font face="Verdana, Arial" size="2">Originally posted by lonsal:
Thanks,
Lon Salgren
Top-Down Solutions
</font>
Thanks,
Lon Salgren
Top-Down Solutions
</font>
'87 IROC 5.7l TPI - original owner!
Someone already made that suggestion. I am waiting for a sample guide and the seat frame assembly where it mounts. But it seems do-able. I only wonder what the market for those would be? The hatch pull-down units were a common option from 86-91. The power seats less common. But yes it is a potential future product for Top-Down Solutions. Thanks, Lon.
