Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
vortec flow numbers
Old Dec 12, 2003 | 06:42 PM
Mo's Avatar
Mo
vortec flow numbers
I just got back my flow numbers for a set of vortec heads with upgraded springs and 1.94, 1.60 (bigger exhaust) ss valves.
sallee chevrolets (sc) numbers for comp:
mine I/E : sc I/E
.100 62.3/53.1 : 58/43
.200 124.5/105.9 : 114/88
.300 178.2/126.4 : 173/125
.400 218.3/ 132.7 : 216/143
.500 225.7/136 : 225/149
.600 221.3/137.5 : 222/152
I was hoping the bigger exhaust valves would help, but I think I might need to do some porting in order to take advantage of them.
Its for a blazer though anyway, so its only going to run at like 4500-5000 max.
Old Dec 14, 2003 | 07:00 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Well your numbers are very close to the results I got with stock vortec heads on the flow bench.
Yes the exhaust port will need some porting to see the benefit of a larger 1.6 valve. You do not need to make the port exit huge. But the valve bowl and guide boss
can use some opening up and streamlining.
From there, general port cleanup is all that is nessessary.
re-flowtest after porting using a flow pipe attached to the exhaust port. Should be able to get it up to the 180cfm +range easily.
The exhaust port actually responds to general porting techniques more readily than the intake port.
Mostly because it is smaller to start with.
As a note, I got the intake port up to 245cfm @.500" with new 2.02's and moderate but complete general intake porting and cleanup.
The valve job is critical.
Old Dec 15, 2003 | 03:25 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Which casting vortecs are those?
Old Dec 16, 2003 | 11:05 AM
F-BIRD'88's Avatar
mine are 062's
Old Dec 18, 2003 | 01:04 PM
Mo's Avatar
Mo
062
the guy who flow benched mine did it with the pipe also and said it was about 4% better than these numbers.
z 28 jari
Sep 14, 2021 10:03 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
toronto formula
Sep 10, 2015 07:31 AM
89fast5oh
Sep 8, 2015 09:55 AM
