Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
world 305 Torquer heads
Old Nov 6, 2001 | 10:18 PM
1986CamaroIROC-Z's Avatar
Has anyone used these heads on their 305 TPI car. If so, are they anygood, and is it worth it to get them ported. Your responses are greatly appreciated.
Old Nov 8, 2001 | 11:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Popular Hot Rod did a dyno comparison of those heads on a fresh .030"-over 305 TPI to stock heads that had a 3-angle valve job done on them. They pocket-ported the Worlds before bolting them on. With a mild Compucam (both tests), they picked up 50 HP with the Worlds.
As to whether they should be ported, two points:
1) Every magazine evaluation I've seen of these heads had them pocket ported - they didn't even bother comparing unported and ported.
2) Before I put in my order, I emailed World with my intended combo and asked them what they recommended, stating I intended to follow the Standard Abrasives do-it-yourself guidelines (www.sa-motorsports.com ). Their response was "Concentrate on the bowl area." I did the full SA job anyway.
They are quality parts otherwise. Should be able to give butt-dyno results after the weekend to answer the "are they any good" part.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4 (restalled TC). Ported World 305 heads, Crane PowerMax cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster. 2.93 limited slip, Spohn SFCs. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Jake_92RS
Jan 28, 2020 10:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
