CAT Stainless Steel Roller Rockers
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I purchased some CAT (www.catpep.com) stainless steel roller rockers from a reseller on ebay, for $159.00
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2448011893
I got the box yesterday and examined them.Very very nice machining. Rebuildable roller bearing, etc.
I put them on the car tonight with some comp-cams pushrods (for roller lifters), and after some guide-plate adjustment they fit like a charm. The roller pretty much stays on the center of the valve throughout the entire operation. Thats nice!
Whas better is they clear the factory valve covers (1985 parimeter bolt). They make a narrow body version for centerbolt covers too.
So from purchase to this point, I'm happy. For $159.00 they are a terrific deal!
-- Joe
-- Joe
they look like comp rockers, or a copy of comp rockers near i can tell. come back after 50,000 miles and report how they work and hold up. i think i'll stick with comp rockers, only thing from comp i use.
Car: 84 Z28 Camaro
Engine: 350ci
I bought the CAT Al roller rockers, took one look at them and
threw them in some far corner of the basement. I would not
re-sell them for $50. (paid $137 for them). Hope they improved
their quality.....
their quality.....
This is the stainless steel rockers. The alum ones are kinda poor quality, I agree. But then again, who would run alum rockers anyway!?
-- Joe
-- Joe
1 Post
Car: 1992 B4C 1LE
I was going to run them, a whole lot of other parts places cranks and rods are secretly really CAT. They dont want other sellers, dealers to buy in and compete so the CAT name is left off alot of stuff. The CAT black aluminum rockers are way better finish than the crane stuff. closer on par with harland sharp or scorpion. Now the proforms, thats a whole other story. they look a little scary, they dont hold up to any serious spring pressures for long but there was a set on the 91 Z I picked up and they dont look ruined after about a year of use with Pioneer/Elgin "Z28" springs (the 0.500"- 0.525" lift springs found on most Dart and world street spring packaged heads)
Though, now i wanna get some 1.6's for the new setup.
1 Post
Car: 1992 B4C 1LE
the new cat rocker setup (not stainless) and under $300
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7933006258
Originally posted by 84305HO
Did you go 12.40 with the T5 transmission ?
-- Joe
Car: 1987 Trans Am
I used to work for a CAT distributor in Atlanta, and will say that they do have something in common with Eagle and some of the other less expensive parts on the market; they are forged/cast in China, maybe from the same place, but that is where the similarity ends. The quality control and machining done by CAT isn't near to the level of Eagle, Scat, or any of the other bargain-priced imported stuff. I'd run used stock parts over CAT. Seeing what I did every day, I'd run anything BUT CAT. Interestingly, a lot of the CAT cranks we received were in Eagle boxes that were all marked up. When I asked a supervisor about it, he told me that CAT bought the "second quality/rejects" from Eagle and others. From the return ratio we had on their junk, I believe it.
1 Post
Car: 1992 B4C 1LE
If this is true then what gives with all of the parts offered by CAT that are not offered by other manufacturers?
My rods are "AMS rods" I believe them to be no better than CAT.
Car: 1987 Trans Am
I'm not familiar with those rods, but we did get tons of complaints on their cranks, harmonic dampeners (saw several that came apart), rockers (needle bearings coming out), water pumps (cars overheated, worked fine with stock pump), etc, etc. I have no financial interest in CAT or any of their competitors, I'm just passing along info that most people would never know until it was too late. Maybe they have improved since then (about two years ago), but I wouldn't risk my engine over it.
Originally posted by LT1guy
Not true, at least as far as their cranks and rods are concerned; I can't verify that someone isn't reselling their other parts under a private label, but if they are they are likely junk, too.
I researched this extensively. The I-beam rods are machined in the US by scat/eagle, but the CAT rods are machined there. the H-beams are all machined there. The cranks are machined here, or there for CAT.
If you think eagle or scats "quality control" is superior, then you'd better start researching.. Both companies have had a TON of bad publicity over broken cranks + rods. Not just recently, as far back as 2000.
-- Joe
-- Joe
Car: 1987 Trans Am
Originally posted by anesthes
CAT, SCAT, EAGLE and about 5 other companies buy rods, cranks, and other items from the same chinese foundry. Some of the items are machined there, others are machined back here. But basicly, your buying the same thing.
-- Joe
-- Joe
1 Post
Car: 1992 B4C 1LE
Tom, those are some SEXY pistons. What are they??
-- Joe
-- Joe
custom ordered JE 4.155 x 1.384" dish pistons (ordered for this project in 1995)
-- Joe
1 Post
Car: 1992 B4C 1LE
Hrm. What size rod and crank?
-- Joe
-- Joe
now it will be a calculated (68cc head, 4.180" had gasket bore/.039" thickness, .016 "in the hole", 21cc dish) 8.67:1 streetrace/blown 353 cid engine with 6.000" rod / 3.25" stroke / 4.155" bore.
They were originally purchased for a 9.5:1 (64cc head) street/nitrous 416 cid engine with 5.700" rod / 3.832" crank / 4.155" bore.
-- Joe
1 Post
Car: 1992 B4C 1LE
truth is that I am merely assuming, a 9.025" deck height. the deck has been cleaned up but until I do atleast a mock up I can't say for sure how far. if its worse than that it will be going for some more decking. if it is less...well, we will cross that bridge when we get there.
-- Joe
1 Post
Car: 1992 B4C 1LE
Well your crank/rod/piston combo works out exactly at 9.000". I'd deck the block 20thou (after measuring of course, and finding out its truely a virgin 9.025" block).
-- Joe
-- Joe
its not, I just cant remember how far I went
On my steel crank, if any of the journals are off we're gonna cut it to try and re-align it. THe Scat rods should be dead nuts on. With my new steel crank + rods + piston, should be 9.015" installed. So we'll cut 10thou off it.
-- Joe
1 Post
Car: 1992 B4C 1LE
yeah if you do the math on mine:
6.000 + 1.384 + (3.25 / 2) = 9.009
thats where I came up with the .016 from 9.025 (assumed)
1 Post
Car: 1989 Iroc Z L98
1 Post
Car: 1992 B4C 1LE
I do! thats why I mentioned it, but I already bought stainless comps before the cat stainless or these ones came out
Hotrodboba400
12-10-2019 07:07 PM
blackandblue02
09-10-2015 08:19 PM
