Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Which Is Better?
Old Jan 4, 2004 | 08:21 AM
Dr. Suess's Avatar
Car: 1986 Chevy Camaro IROC-Z
Which Is Better?
AC Delco 608E WIRE SETS
Ships in 1 day
$43.88
or
Accel 5040B
8mm SUPER STOCK
Ships in 1 day
$45.28
Old Jan 4, 2004 | 08:26 AM
Dr. Suess's Avatar
and between these plugs
Autolite Ignition APP24
Premium Spark Plug: Double Platinum; Gap .035
Ships in 1 day
Weight: 0.1 lbs.
$3.97
Autolite Ignition AP24
Premium Spark Plug: Platinum; Gap .035
Ships in 1 day
Weight: 0.9 lbs.
$2.48
Autolite Ignition 24
Standard Spark Plug: Gap .035
Ships in 1 day
Weight: 0.1 lbs.
$1.24
Bosch 4207
Platinum Part: Gap .035
Ships in 1 day
Weight: 0.2 lbs.
$2.14
NGK 7401
Platinum; UR4VX; @ Gap .035" @; Tuned-Port Injection
3 Month Limited Warranty
Ships in 1 day
Weight: 0.4 lbs.
$6.99
NGK 6630
V-Power; Resistor; UR4; @ Gap .035" @; Tuned-Port Injection Ships in 1 day
Weight: 0.1 lbs.
$1.68
i had accell wires and plugs picked out but was looking throught the board and found out that alot of people dont like them
Old Jan 4, 2004 | 12:07 PM
ede's Avatar
ede
better for what? you need to say what your application is.
Old Jan 4, 2004 | 01:08 PM
Dr. Suess's Avatar
1986 chevy camaro z-28 with a 305ci
and
1986 chvy camaro IROC-Z with a 400ci
and
My friends 1986 IROC-Z with a 350ci
Old Jan 4, 2004 | 08:52 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I run the super stocks on my RS, and I only run AC Delco or NGK spark plugs in everything I own
Old Jan 4, 2004 | 09:34 PM
87IROC350's Avatar
Engine: 5.7
None of the above. AC Delco for Plugs and Taylor Spiral Pro's for the wires (can be ordered through Summit). Can't go wrong.
Old Jan 5, 2004 | 02:59 PM
Dr. Suess's Avatar
which ac delco plug number all they have at advance is r43ts
Old Jan 5, 2004 | 05:00 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
you can use those, or rapid fires, I think mine are "2"
