Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
SLP Cold Air induction ....
Old Oct 23, 2000 | 11:45 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Does anyone have this kit:
21010 1990-‘92 V8 Single Inlet
If so, what is contained in the kit?
I currently have the Random Tech Ram-Air kit which is very nice. But, with the kind of horsepower that I put out I am seeing my MAP decrease from 100 to 96kPa during a WOT run. I believe I have an inlet restriction in the stock camaro airbox. Yes - I have totally gutted the airbox and it is being force-fed fresh air through the Random Tech kit. However, I am still seeing a restriction. My bet is the entry into the airbox closest to the throttle body. That area has a very small diameter. I want to replace the airbox and ducting to see if it makes a difference. SLP is really the only company that makes a cold-air kit for our cars.
I would love the dual cold air kit but I am not looking to put the battery back in the trunk. I use to have it there but then moved it back to the front. So, it would have to be their single inlet system. Does anybody have any pics??
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Oct 23, 2000 | 12:07 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
It is similar to the 86-89 kit with the exception of the air tube from the box to the throttle body. The tube for the MAP cars is 1 piece of ABS(I think it is abs) plastic. Here is the dual inlet picture. http://www.slponline.com/slpperforma...mage/21030.jpg Picture it without the right hand side and you have the single inlet.
James
If the women don't find you handsome they should at least find you handy
Old Oct 23, 2000 | 12:13 PM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
I am sure that you could easily make that SLP system yourself for way less.
1991 Z28 5.7L, Edelbrock headers, Eldebrock intake base, SLP runners, GMPP 1.6 roller rockers, Hypertech Theromaster chip w/ 160stat, Accel 300+ race wires w/sleeve, MSD coil, relocated MAT, TB bypass, K&N's in gutted airbox
Old Oct 23, 2000 | 02:46 PM
TRAXION's Avatar
The biggest problem is the coolant hose from the radiator to the intake. Its pretty much in the way if you want to route a nice 3-4" tube there I think the SLP Kit may use a different radiator hose. Does anyone know about this??
Tim
Old Oct 23, 2000 | 04:01 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Hey Trax...I have the kit for the MAF setup, but the SD setup is essentially the same. The kit doesn't come with a different radiator hose. I know SLP says to relocate the battery to the trunk, but I just relocated mine to the drivers side like the Firebirds. Here's a crappy pic:
I just relocated the charcoal canister behind the front bumper IIRC with a couple of large tie straps. It works great, you'll have to extend the vacuum hoses and wiring. HTHs
Okay, that didn't come out...I'll just email it to you if you want.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
[This message has been edited by IROCZZ3 (edited October 23, 2000).]
Old Oct 23, 2000 | 08:42 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
Tim,
Is there any way you can get ahold of a K&N throttle body air filter - just to see if it changes your MAP readings?
Old Oct 24, 2000 | 12:23 AM
noam's Avatar
i'd like to see successful install pics of this system on a Speed density car, i've been waiting some time to get this because i dont want to waste the $$ on it and be unsuccessful fabricating a way around moving the battery.
Old Oct 24, 2000 | 04:36 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have the dual SLP intake and like it. The radiator hose is no problem. Take a regular water neck from a TBi motor, flip it backwards and head to the autoparts store and find a flexible upper hose to fit. Works like a champ! I can e-mail you a picture of mine.
Rob P
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 24, 2000 | 05:23 PM
noam's Avatar
yeah could you please send me pics email is noamaniac@aol.com
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
jimmy harris
Aug 31, 2015 03:09 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
