Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Hypertech Dist Cap, Coil, And Rotor Kit.
Old Jan 25, 2004 | 10:30 PM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Is it worth it guys?
-Jensen
Old Jan 28, 2004 | 02:59 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
The Hypertech stuff would be a great addition if you added a better modulator. The HEI's weakness is in the higher rpms. The Hypertech kit with an aftermarket modulator would cure those woes provided you had a good working HEI to begin with. If you decide to do it, pull the distributor out and clean it up real good. Make sure the advance plates move freely and aren't all gummed up.
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jlanz55
Sep 9, 2015 09:09 AM
TBRays98
Sep 6, 2015 05:05 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
