Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
GMS has an adjustable MAF for TPI cars, what do you think?
Old Mar 31, 2004 | 06:42 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Apparently, GMS is marketing an adjustable MAF sensor for TPI cars. GMS claims that it flows 30% more air than stock with the screens attached and its adjustable. A simple turn of the screw will alter the signal set to the ECM, thus, affecting the AFR.
How about some opinions here.
Old Mar 31, 2004 | 07:28 PM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
what's the point?? u wont see any more hp tpi is the restriction... it's the same for bigger tb's... the money can be spent on better mods.
Old Mar 31, 2004 | 07:36 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Yes, the MAF is the restriction. But GMS is claiming an increase of 30% more air flow than stock, and that is with the screens intact.
So, is the inside diameter larger? If so, then I would be interested.
BTW, it sells for something like $450!!!!!!!!!!!!!!
Old Mar 31, 2004 | 10:33 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Thats an awful lot for an MAF.... If you wanna adjust the a:f ratio, hell buy a cheaper high flow non-adjustable MAF, and buy an adjustable fuel pressure regulator. The regulators usually go for around $60-$80 with what I've seen.
I paid $280 for my GMS MAF...granted it's for a SBF, but everyone I talked to told me I overpaid.
And FYI, make sure you order the version for a cold air intake. I have the stock-style one and I can't run a cold air intake because the MAF freaks out. It's FAR too sensitive in my opinion. I can't even run a K&N filter because the small traces of oil get onto the MAF and I lose power and it starts to stumble.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
86IROC112
Aug 17, 2015 02:00 PM
