Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
headers
Old Sep 23, 2004 | 03:05 AM
BRYAN BUSH's Avatar
Car: 91 Z28
Transmission: BORG-WARNER T-5
headers
What is a good but less expensive set of headers to put on a 91 Z28.What kind of horsepower gain would i get and would it cut any time off 0-60 time.How hard are they to put on and is it worth it
Old Sep 23, 2004 | 03:19 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Look at Hedman or Hooker 1-5/8" shorties. Can't remember the part numbers right now, but they are a good price and pretty nice quality stuff. I have the Hedman 1-5/8" headers, and they are really nice.
Old Sep 23, 2004 | 11:36 AM
91blackz's Avatar
Car: 91z
Engine: 5.7 TPI
A good set of headers is deffinetly worth the money, and in my opinion you get what you pay for. I put SLP's on mine a couple months ago and pulleys and gained over .3 and 3mph, not to mention a better sound. If you cant afford SLP, then hedmans should also work well, i havent heard alot of great things about the edelbrocks.Plan to spend a good weekend on putting them on, but its not that bad.
Old Sep 23, 2004 | 11:53 AM
arlockstedt's Avatar
Car: 89 Firebird Formula 350 WS6
A good weekend installing headers....lol.....took me around 2 hrs tops. I used the Hooker Super Comp Shorties ( part #2055) They are 1and 5/8 and came with a really nice y-pipe. Although my install was really easy because i had already removed the pollution junk and A.I.R tubes. I would really recommend this set for any thirdgenner. Summit sells the setup for around 360.00+ shipping. Feel free to ask me any questions about the install.
Old Sep 23, 2004 | 12:02 PM
BRYAN BUSH's Avatar
Car: 91 Z28
thanks for all the help.Im sure ill need more
Old Sep 23, 2004 | 09:11 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Cheap and headers don't go together. Anyone who has flowtechs or dynomax headers knows exaclty what i am talking about. It is not worth the hassle, problems, poor quality, time, effort, or busted knuckles to go with any cheap header. Go with the Hooker 2055's ($350) and be done with it.
Old Sep 23, 2004 | 09:12 PM
Another good opinion...Hooker Super Comp Shorty's
Old Sep 23, 2004 | 09:44 PM
BRYAN BUSH's Avatar
Car: 91 Z28
thanks for the info ill go with hooker
Old Sep 23, 2004 | 09:53 PM
any ?'s on install, just let me know...be glad to assist.
Old Sep 23, 2004 | 10:38 PM
ljnowell's Avatar
I got the flowtechs, because i am a poor person, lol. I dont think there is a problem with performance, they just fit like total crap. They were a bitch to bolt to the engine, on the stand! Then when in the car, both sides header flange hits the frame rail. Talk about a PIA to install the y-pipe. Next time it will be SLP's for me, they seem to fit very well.
Old Sep 23, 2004 | 11:14 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I feel your pain man. Although my fitment was awesome the quality was nothing short of high school shop class. Every flange was bent and I could only seal them with Percy's dead soft gaskets. These gaskets are miracle workers. Anywhoo, the collectors to this day leak even with $30 in high tech fancy collector gaskets stuffed inbetween. Here is a pick of 2 hour old flowtech flanges. Note the bent bolts and flange.
Old Sep 24, 2004 | 02:46 AM
ljnowell's Avatar
I didnt have any problems with the collectors, but all of the welds were sloppy. I probably could have done as well with the 110v wire welder. But, they work for the time being. Probably the worst part IMO was the flange that bolts to the block, it seemed to be warped, it was a struggle to get them bolted on, for my sake I hope they never have to come off and be put back on while in the car.
Old Sep 24, 2004 | 06:51 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
I can also contribute to the flowtechs being impossible to seal. I have installed them three times, used aluminium gaskets twice and they still leak. When I first tried to reinstall them I was (somewhat) shocked to see the included paper gaskets leaking everywhere, literally. Every primary, and both collectors where leakers (these were all still torqued mind you). My crossover tube also needed clearenceing to get past the k-membe right behind the oil pan, although this could have been the falut of the num-nuts I had install them.
Old Sep 24, 2004 | 08:28 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I forgot to mention the crappy welds. I am glad you did. Just like yours my head flange was really warped. I mean, when I had one bolt in the flange was .5" off the surface of the head on the other side. Thank *** for percy's dead soft gaskets that can fill in such a void.
Old Sep 24, 2004 | 09:29 AM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
I know Im going to get hissed out of here, but if you're thinking economy and having the absolute best isn't your most important concern, then you may want to think about the edelbrocks. Easy install, they come with EVERYTHING you need (gaskets, y pipe, bolts, everything) they are cheap, especially considering, like i said, they come with everything you could need, and last but not least, you will def. notice a performance gain, im sure its not as much as a nice set of slps or hedman ect. but it's def. there.
Old Sep 27, 2004 | 09:05 AM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
I got 20hp at the rear with Edelbrock TES and a high flow cat. Mods before this were Edelbrock performer intake and carb, Hooker catback 3", open air elelment with KN. This is on a 87 LG4.
However the Edelbrock y pipe I just measured it and was either 2" or 2 1/4" which kinda sucks, plus like a true idiot I'm running a 2 1/2" cat. So basically I got somewhat of a bottleneck before the catback, but not as bad as stock.
Old Sep 27, 2004 | 10:36 AM
Cheap isnt always the best route.....You get what you pay for! :lala:
Old Sep 27, 2004 | 11:46 AM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
I thought I was pretty clear on what I said about the TES's. I said they might be something to think about if youre on a budget and having the best isn't an issue. I've had mine for almost two years now and considering what I paid for them and what you get when you buy them, Im more than happy with them. Im well aware that there are MUCH better headers out there, but these will still give you a kick in the pants.
Old Sep 27, 2004 | 11:54 AM
what did u pay for the setup?
Old Sep 27, 2004 | 05:57 PM
1991project's Avatar
Car: 1991 Z28
Engine: 408 LSX
Transmission: Pro-shifted T-56
Axle/Gears: 9"
what are the options/ opinions for long tubes, i'm lookin into building a stroker motor, and how big will depend on how much air i can move.
Old Oct 1, 2004 | 07:20 AM
mcwille's Avatar
Car: 1987 Trans am 5.7 TPI
Engine: 5.7 TPI
ok i bought a set of dynomax black jack shorty headers off a friend they are brand new and i got them for a $100 i know they retail for something like $160 but will it be worth it will they give me a good kick see i am a very poor person most of the parts on my car are home made fabs i made my self although i don't have much money i am somewhat talented to that aspect.
when i install these headers i plan on running true duels all the way back will these headers be fine for that?
any help or experiance with these headers would be nice
thanks
mcwille
Old Oct 1, 2004 | 10:47 AM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
As long as you dont have emissions or a visual check rather(cause i dont think they have air), any header is better than stock manifolds, and no one can argue with that. You may need to weld on a bung for the O2 sensor with those also.
Old Oct 1, 2004 | 11:06 PM
philapino18's Avatar
Car: 88 Camaro
Engine: 305 TBI
First off, sorry not to hi-jack your thread but what about the headers that Summit sells in their catalog? Does anyone have any info about them, because they're around $75 bucks plus shipping.
Old Oct 1, 2004 | 11:11 PM
ljnowell's Avatar
From what I have been told, and have seen, they seem to be nothing more than flowtechs. If you read my post above you will get a good evaluation of them.
Old Oct 4, 2004 | 09:33 PM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
this all sounds like more praise to the 2055s. I think ill have to go with them finally. Any installation quirks about them that i should know
Old Oct 22, 2004 | 12:02 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Borlas are nice if you feel like paying for them. You can find a good deal on ebay sometimes.
Old Oct 22, 2004 | 12:36 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Borla only makes mufflers and a cat-back for our cars and not headers.
Old Oct 22, 2004 | 06:37 PM
nick418's Avatar
Engine: L98, Hemi 6.2
lol, i got edelbrocks comin for my 91 Z28. I herd good things about them (ppl who own them)
Old Oct 22, 2004 | 07:25 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Really, that sucks.
They didnt really help my truck out, but was going to get a pair for the camaro anyway. Not anymore I guess.
Old Oct 26, 2004 | 09:07 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i've got a set of the hedman shorties and y-pipe. fit pretty decently. on a budget, they were nice enough.
Old Oct 28, 2004 | 10:56 AM
91TG's Avatar
Car: 91 Camaro Z28
Engine: 350 L98 TPI
Axle/Gears: 3.23 posi
Going to replace the exhaust on my 91 Z28 L98 700r4 and it has dual cats...if I install headers or just replace the exhaust from the manifolds back 1) does the y pipe go into 1 3" pipe to the cat or 2 like stock and 2) (not wanting to buy 2 cats if I don't have to) will 1 3" cat with a single 3" system (y pipe to muffler) flow as good as the dual cat system?
Doesn't really say or show this in the ads for the pipes. TIA
Time to get it off the jack stands ( been there for like 3 or 4 years now) and feed it a couple of Mustangs
PS This site is great....where have I been all this time
Old Oct 28, 2004 | 07:42 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
As long as its legal (if you care) and there are no issues with the hangers, i don't see why you couldn't do that... get headers with a ypipe and connect the y directly to the cat like in single cat applications and then get a single cat cat back exhaust.
Also, if you compare single cat to dual cat STOCK exhausts the dual cat gives you 5 hp more, IIRC. However, if you get any AFTERMARKET headers/ypipe/single cat setup, it is going to blow away a dual cat stock setup.
Old Oct 28, 2004 | 08:07 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
hooker 2460s and a custom y pipe worked great for me
Old Oct 28, 2004 | 11:31 PM
Camaro4me's Avatar
Car: 1991 Camaro RS
Engine: 5.0L 305 V8
I was wondering if there are any headers of good quality that comply with the California smog regulations.
Old Oct 29, 2004 | 06:38 AM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
I belive the SLP headers are smog legal as well as the hooker 2055s
Old Oct 30, 2004 | 12:29 PM
Camaro4me's Avatar
Car: 1991 Camaro RS
Engine: 5.0L 305 V8
Thanks for the help. I'll look into those.
Old Oct 30, 2004 | 07:32 PM
92zz28's Avatar
Car: 1992 Z28
Engine: 305TPI
Transmission: 700R4 with B@M kit
I got a pair of Hooker Competition (not SUPER Competition) shorties for my 91Z for only $150. They are just black coated though. I think Summit has them for around this price too.
Old Nov 13, 2004 | 09:22 PM
bolinger89z's Avatar
Car: 89 Iroc z
Engine: 350 TPI 5,000 miles on new engine
Transmission: 700 R4
the supercomps are 1 5/8, and the slp's are 1 3/4. does that really make a huge difference. Somewhere on another post in here, someone told me that 1 5/8 wasn't too good..that i should go w/ some slp 1 3/4. I plan on doing cam, intake, heads and stuff so i didn't think 1 5/8 would be so much smaller that it would make a huge power make a huge flow difference. Nebody know if this is true or not?
thanks
Old Nov 14, 2004 | 08:13 PM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
you can check around and youll find some more info. For the most part, 1 5/8 is good for applications with less than 450hp. Once your pushing 400+ you want to start considering something bigger like 1 3/4 because your exhaust would actually be a restriction. Now some have diff opinions and ive seen some 4th gens with only 1 5/8 headers pushing 500+ hp. if youve got a 305 then your perfectly fine with 1 5/8. if youve got a heavily modified 350/383 and up then consider 1 3/4.
Old Nov 14, 2004 | 08:25 PM
_max_'s Avatar
how are you liking the 2460s I just but a set for my car and have not installed yet, how do they sound and how was the fit up
Old Nov 14, 2004 | 09:26 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
fit was great, sounds sweet with the gale banks catback and high flow cat i put on at the same time. quality was excellent.
Old Nov 16, 2004 | 06:40 PM
  #42
_max_'s Avatar
thanks for the good reply firebirdpl
Old Nov 16, 2004 | 09:30 PM
  #43
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
no prob max let me know how the install goes im sure you wont regret it
Old Nov 17, 2004 | 02:46 AM
  #44
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Camaro4free i have the 50 state legal edelbrock headers and they made a huge difference in performance and sound, also the car passed with those and a 3 inch exhaust 3in high flow cat and new muffler. In fact the car ran cleaner then my friends 99 stock civic with same amount of miles as my car
Old Nov 17, 2004 | 09:38 PM
  #45
_max_'s Avatar
T56 in 3 weeks puting syncroes in it this weekend,getting spec clutch repaired,headers hopefully thanksgiving day weekend PRICELESS
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
