Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
what do you think of these heads
Old Mar 24, 2005 | 11:43 AM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
a lot cheaper than taking my416's and having everyhting done at a machine shop.
http://amperformanceheads.com/58cc.htm
Old Mar 24, 2005 | 05:41 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i can't find a casting number for these heads anywhere on the site, and it appears that the do NO porting to the ports. which would be necessary to me. i see they unshroud the chambers for the larger valves, but do NO blending. get some jy 416's and port them youself and go have someone put some screw in studs and guide plated on and the larger 1.94" intake valve. it will be cheaper in the long run when you consider the price of all the upgrades and then shipping.
with the way i am going to be doing my heads, i would be giving them over $800!
Old Mar 24, 2005 | 10:42 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
they use 416's and 081's
i have some 416's but after adding in new valves,springs,retainers,guides, plus machine work, i think it would be cheaper and easier just to buy some aftermarket heads.
after adding up everything from the summit catalog for a head overhaul and cam swap im at $900 without the machine work.
seems like i might as well wait a little longer and just get a longblock and have a new engine.
why do you need a guideplate?
Old Mar 25, 2005 | 05:48 AM
mw66nova's Avatar
Engine: 7.0L
guideplates keep the geometry all square. especially if you run a large cam or a 1.6 rocker is when they are good to have, cause you have to elongate the pushrod holes in the heads, which, from the factory are what is guiding the pushrods from getting all hay-wire.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
