Comp Cams Desktop Dyno
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Is this any better than the Desktop Dyno 2000?
More detailed infomation, such as heads, intakes, etc?
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
If it's from Comp, then it better have cam profiles already loaded for their grinds. If not, then I don't see how it would be different.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Comp Cams is distributing the 2004 version I believe. There are a few changes over the 2000 version, such as the ability to vary ramp profiles and the ability to model engines with variable valve timing.
