Door Seals & Window Sweeps EBay's-A1Auto =A+
1 Post
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Door Seals & Window Sweeps EBay's- 1A Auto =A+
TGO Guys,
Just received new Window Sweeps and Door Seals from 1A Auto. They look very very good and I believe the price was FAIR (i.e not really cheap.....but not really too expensive either)
[Qty] [Item number] [Description] [Unit Price] [Ext.Price]
1 1A-WSD-00296 82-92 GM-F Door Seals $64.95 $64.95
1 1A-WSS-00023 82-92 GM F out belt w/s LH $28.98 $28.98
1 1A-WSS-00024 82-92 GM F out belt w/s RH $28.97 $28.97
A1Auto responded to quickly to E-Mail questions and seems to be interested in doing ethical business.
Just thought you should know..... I found a couple dirt-bags on E-Bay and when you find a good one I think we should share the info.
Sincerely,
Kurt
http://stores.ebay.com/1A-Auto-Inc-All-your-Parts-Needs
Currently preparing for a new coat of paint and decided to replace all the seals...
Sincerely,
Kurt
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Thanks for posting this. I've seen that seller's auctions on eBay, and will be purchasing a set of sweeps over the winter. Good to know.
Has anyone bought the power window motors they sell? I bought the plastic piece for the rear hatch pull down motor. Top Quality piece. Oh, why are some motors 9 tooth and some 12 tooth? Do I have to pull the motor out first to see which one I need? I can get a motor at the dealership I work at for $110, the parts guy did not know if it was 9 or 12 tooth.
Car: 1986 Z28
Engine: 305ci
I have purchased 2 window motors for my car from them. One is at least a year old and the other this summer.
The service was good and the price was good. I bought the first from eBay and the second from their site directly.
In the case of motors, they had 2... one was a cheap import version. It was less than the OEM version. Stuck with the OEM unit for 10 bucks more and have not regretted it.
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
