Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Anyone ever hear of engine quest cyl heads??
Old Mar 21, 2006 | 09:39 AM
project86ta's Avatar
Car: 86 TA
Engine: 305 carb
Transmission: 700 R4
Axle/Gears: Not Sure
The company that I work for has started using some of these heads for their performance applications. Anyone ever hear of them their website is http://www.enginequest.com/ they also have flow numbers for their heads if anyone is interested.
Old Mar 25, 2006 | 09:02 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
They are making the old protopline heads. I have spoke with them through email a few times and are redoing the aluminum heads completely to try and fix all the problems with them.
Old Mar 26, 2006 | 11:10 AM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
you mean you might actually be able to get a normal unmodified socket to fit in the head bolt pockets. my friend bought pro topline 220cc's alum and we had to grind down sockets to make them thinner to tighten the bolts. it really sucked.
Old Mar 26, 2006 | 12:03 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
The EQ heads are made at a completely different foundry and they are supposedly trying to improve on the pro topline heads. The original Topline foundry is producing heads for RHS and supposedly have an improved QC to eliminate the mistakes that Topline made. Lots of guys like to get the old topline heads since you can get them for practically nothing but its hit or miss with them. I got a set luckily the only problem i had was that the rocker stud bosses were tapped to shallow.
Jae992
Aug 27, 2015 09:07 AM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
