b&m console mega shifter?
anyone have it in their camaro? being specifically made to fit in our 3rd gens, did anyone have troubles gettin it to fit in the console? also, i was wondering if buying the shorter shifter arm would be worth it, for i think the stock arm might be a little high and feel wierd to shift...if its somewhat close to the stock shifter height it would be awesome but who knows? any comments would be awesome
thanks
thanks
Since you are a newb you need to be aware of the search function.
This question has come up before.
I thought about doing it and decided not to. IIRC there is a kit that you can install which gives you the benefits of the b&m without the problems.
Good luck.
Good luck.
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
I have it in my IROC, it was installed by the previous owner. I really like it and wouldn't change anything about it. But, as Parrydise7 says
as this has come up often and you will get a lot opinions to help you out.
