jongbloed hood problems
Car: 86 z28
Engine: 383 stroker 550hp 540 tq
Transmission: t56
i just recieved my new hood and seems not to fit correctly has anyone else had these problems with g & t fiberglass?
Car: 88' Iroc-Z
Engine: LQ9
most of the hoods from these manufacturers don't line up and have to be worked to match the stock appearance. I think it's dumb spending that much money then having to match that with a bodyshop to straighten it out.
Car: 1992 Camaro RS
Axle/Gears: Stock
I'm willing to say that 98% percent of aftermarket hoods require adjustment to get them to fit right.
And Snketr: how does your car handle all that toque from the engine? What frame modifications have you made? I want to build a kick *** 396 but don't know how much the car can handle. And I really don't want to weld in a roll cage. Thanks man.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by ScottyRS
I want to build a kick *** 396 but don't know how much the car can handle. And I really don't want to weld in a roll cage. Thanks man./
Car: 86 z28
Transmission: t56
abuse
the car has fully welded sfc's and a full cage the car seems to handle it well. i also have the tublar k member and that really helped alot. it also has a 9 inch cause the 10 bolt would not hold, but back to the hood it doesnt come close to lining up, the bottom of the cowl hits the fire wall and to make it sit right it sits 2 inchs forward of where the stock hood was. im just confused cause my buddy has one and it fit great, but y is mine hitting the firewall?
Originally Posted by snketr
...but back to the hood it doesnt come close to lining up, the bottom of the cowl hits the fire wall and to make it sit right it sits 2 inchs forward of where the stock hood was. im just confused cause my buddy has one and it fit great, but y is mine hitting the firewall?
Car: 1992 Camaro RS
Axle/Gears: Stock
Originally Posted by Street Lethal
First, I would make it a point of measuring your hood, in comparison to you're friend's hood. make sure it's of adequate length. If it is, I would then measure the distance of your friend's firewall to nose, fender to fender, as well as his hood hinge location. Bottom line is that you either have a bad mold, or your body is mis-aligned... despite the stock hood fitting right in place. Hope this helps....
Sometimes you just get a bad hood. That's why you're supposed to test fit it before paint.
Car: 1992 Camaro RS
Axle/Gears: Stock
That's what I meant when I stated that he either has a bad mold (fiberglass hood), or his body is not properly aligned...
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
i want the ram air 2 hood but im starting to get nervous about all the work entailed, because my car has been in a front end collision with the previous owner, maybe i should just get hood blisters and call it a day...
Car: 86 z28
Transmission: t56
hood
the car has been in an accident thats why i bought it, the hood has not been painted i am just trying to get it back together. talked to someone from gt fiberglass and they said that they would check the mold thanks for the help
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
just a little background on g&t - they've been very helpful to me... They were able to perform some repairs on a fiberglass hood that had been damaged... wasn't even their own hood! Anyways - their business is only 20 minutes from where i live here in CT... If you have any issues, make sure to talk to them, i'm pretty confidant that george or the guys working for him will take good care of you...
Anyways - your alignment problems may stem from the accident, but thats still not a definate solution...
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Mine fit well. I had to elongate the adjustment holes in the hinges ans their instructions said might be needed.
I bet it has something to do with the fact the car has been wrecked.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
3rdgenparts
Aug 6, 2015 09:03 AM
