Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
what heads???
Old Oct 2, 2006 | 10:12 PM
19kilo's Avatar
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
what heads???
I was looking at summit and the parts for sell froum I have no idea what heads i should get 400 ish is about my limmit im runing the stock head out of a 1974 Z-28(350 came out of) not even sure what the spec on them are. What cam should I get im on a fixed buget. Thanks
Old Oct 3, 2006 | 12:50 PM
Shagwell's Avatar
Car: projects.......
If you're looking at a $400 limit, you're not gonna be buying anything new thats worth while. Find a set of vortecs, either off the forums or in a junkyard. Do a little clean-up work on them, have the valves/seats ground, throw on some new springs and call a cam manufacturer or tech line and get their reccomendation on a cam for your combo(vehicle, type of trans + stall speed if auto, gear ratio, intended use, etc).
Vortec heads can easily make good power and are also very efficient.
Do a search, you'll find many reasons to run these heads. The only down side is you'll either have to buy the proper intake for them, or drill and tap them for the conventional intake bolt-pattern and run thick gaskets.
If you don't want to change the intake or do the mod work, find a set of late model L98 center bolt vc heads. I believe the casting number is 082. The 350 TPI's came with them as well as many marine motors. - They decent for cheap, much better than your smog-era anchors.
Old Oct 3, 2006 | 12:57 PM
19kilo's Avatar
would my headers work with Vortec heads?
Old Oct 3, 2006 | 09:54 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Yes, regular headers work with Vortecs. However the roof on the Vortec's are a little higher than standard SBC heads so if you can raise the header to match the port it does help. You do that by drilling out the mounting holes to a slightly lower position and then fill in the top of the hole, thereby raising the header.
Old Oct 8, 2006 | 09:43 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
I would also go for the Vortec heads. They're going to give you the best bang for your buck. Downside is that you would have to get a new intake. But, a combo of new heads and intake could really wake up your car. On my site in my signature, I have some info about Vortec intakes that I used on my car. Let me know if I can be of any help.
Brian
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
