heads
Car: 1986 z28 <sold>
Engine: iron head 383
Transmission: th350
Axle/Gears: 4th gen 3.23 posi
heads
so i want a good set of cast iron heads..I was thinkin about iron eagle heads or the pro topline iron lightning heads..If I go aluminum i want afr's bottom line i want to kno which set of heads will be the best set of heads for a 383 on the street to make 550hp or more and spend around $1100
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You really want to go with aluminum heads, and run about 10.0 to 10.5:1 compression ratio. Also, you will most likely want 195cc intake ports, minimum. But for $1100, you cant buy the AFRs new, you will have to find used AFRs. For new heads, logon to SUMMIT RACING and check out the Trick Flow heads.
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Iron heads are worth the money and if you aren't going to port them then they are even better. Aluminum heads are great, but more costly, for $1100 I agree the TFS heads are a good choice.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
