Another Mega Shifter Question....
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Anyone had trouble getting their adjusted right....I cant get it to go into park right, or 1st gear.......The part that goes on the tranny (The shift bracket) fit loose...Is that normal???? Any suggestions????? If I get it to do park right, then it wont go into drive with one pull....I had a quicksilver before, and never had a problem....Thanks for any help....Tom
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
Re: Another Mega Shifter Question....
i had a lot of issues with this. mine is still a faction off but you can get it cloes. there should no loose parts. i had to pu some washers on my backet to get it tight. Give it time and you have to do little adjustment til you get it right on but once you get it your done.
Car: 89 RS, 92 Z28
Washers is a good idea, you would think it would come with them, but mine didnt.Thanks alot..........Tom
