may have gotten wrong megashifter
i ordered a B&M console megashifter for '82-'92 camaro and its marked correctly on the box but the shifter plate only has 1,2 then drive but ive seen pictures of them with plates that have 1,2,3 then drive, did they send me the wrong one does anybody else have this shifter and if so what is it like on your plate?
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Re: may have gotten wrong megashifter
they usually send you an extra plastic piece to change out the shift pattern. I would check the box again to see if it had fallen out or maybe its under the inside folds of the box.
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
