i work at a parts store and i need a new distributor, and theres an accel piece on the shelf there and it seems pretty well built, i think its billet aluminum and i could get it for about 100 bucks, comes with module, mech. and vacuum advance kits, pickup and cap and rotor, and i was thinking about getting the accel super coil also, i could get it for about 35 bucks, and a set of the 300 race wires for about 50 bucks, just wanted to hear what people though of this setup, and any experiences, thanks guys!
I have the car and rotor on my car plus the 8mm wires, They all suck,rotor burnt out already and makes my car pop at high rpm when i mash it! stay away if you can
wow, really? anyone else have any experiences?
I have the cap, button, wires, and super coil on my car. Never had any problems out of any of it.
I also have the cap, rotor, wires and coil on my car. Never an issue from any of them.
89RS_82Z
close
i only run MSD or Blue Streak on my cap and rotor, but accel makes an good coil, i put the HEI super coil in my caddy and it light that thing up
im running an MSD coil on the camaro, MSD's coil is stronger, but an accel sure beat the hell out of an OEM replacement
I have Accel and haven't had a problem yet...
I ran the accel distributer, cap, rotor, 8mm wires, and supercoil on my last camaro that had a ZZ4 in it and the only thing I didnt really car for was the wires so I switched over to msd wires but other than that I really liked the stuff.
I've been running their plug wires since the '70's on various cars and I've yet to have a problem with them.
search the threads on here about accel, if you aint running tpi or a modified motor its cool but ey, its your call, you'd be better off using ac delco
i have about a 325 or a 350 hp motor, and im planning on getting the distributor, coil, and wires, i can get all that for about 190, i think it would be sufficient on my combo, plus its a pretty good price
I have the super coil and 8mm wires...they work great...Had them in there for a while, no problems
89RS_82Z
close
as said before, anything performance is NORMALY better than OE, i think accel is better than OE, but not the best aftermarket out there, just dont get the replacement CRAP at the autoparts stores.... just my
, but is almost like chevy ford and dodge.......everyone has the one they like, its almost a to each their own thing, whatever works best for you
, but is almost like chevy ford and dodge.......everyone has the one they like, its almost a to each their own thing, whatever works best for youSenior Member
still i say search the boards and most will tell you stay away from accel, but ey every car is different
do not waste your money on Accel parts because they do not make anything but junk.
test the resistance between Accel wire and any other brand's wires, you will see that Accel has higher resistance compared to others.
Also do search on their injectors, coil, or anything they make and find out for yourself.
I hope this will help
thats what i been tryin to stress.... search the boards
Sometimes I laugh. When people have one bad experience, everything is junk. Thats how quadrajets got the bad rep, and a whole host of other parts. Like many of the above I have ran accel wires cap coil rotor, etc on many vehicles and never had a problem. I laugh when people suggest mallory over accel, when they are truly the same parts. Mr gasket owns and makes mallory, accel, lakewood, hayes, and jacobs electronics. They make some quality equipment. Like everyone though, they will turn out some junk. The distributor and whatnot is a good deal, jump on it. If you feel warm and fuzzy with different wires, go for it.
great
I am running a host of Accel products with no problems. I have a 300+ ignition box, 300+ wires, complete billet distributor, spark plugs, and injectors. I did have some problems with the early style injectors, but the new silver style have worked flawless.
i have 92 305 tbi and i upgraded to accel coil and wires... i installed it and went down the road and all i heard was backfire backfire backfire popping popping the harder i hit the gas... went and returned it for another one.. did the exact same thing.. POS MSD coil ran like a champ sec i installed.. some accel parts are ok.. but coils.. POS!!
Typicaly coils don't cause misfires, they either work or don't. I am willing to bet you got your plug wires crossed when you changed them. Plus the odds of getting two bad coils back to back are pretty slim.
Quote:
I backfire backfire pop using accel cap rotor plugs and bosck +2's, I think the problem might lie in my coil which is factory.Originally Posted by Drone358
89RS_82Z
close
your problem is Boush , put them in the trash can and get A/C Delco Rapid Fires, i had the same issue with MSD parts and Boush
Boush and HEI do not mix
89RS_82Z
close
https://www.thirdgen.org/forums/tbi/...e-up-runs.html?
^my and others Boush storys^
BTW it runs alot better with the A/C delco's than it did with the autolights that were in it before the t/u and 150% BETTER than the boushs that are now in the landfill (and they were brand new)
86WS6
close
- Join DateJul 2007
- LocationGreat Smoky Mountains, Bryson City North Carolina
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car86WS6 30K and 82WS7 24K
- Engine86:305 TPI, 82: 305 LG4
- Transmission86:700R4, 82: T200C
- Axle/Gears86:3:27 9 bolt, 82: 3:23 10 bolt
- Liked:3 Times in 3 Posts
Had good luck with Accel coils, caps, rotors, and wires. Had two Accel distributors that ran fine for 8K miles, then developed the backfire/misfire problem. The bushing/bearing is made of of soft metal, and wears out fast, causing the distributor shaft to wobble, which causes the engine to misfire and sometimes backfire. The bushings are replaceble. The Accel rep told me that they are not designed for street use, and will wear out faster than stock.
Quote:
No i never changed my wires after i got my msd coil... trust me it was the coils.. pretty rediculous... ill never go back to accel with their coils.. didn't have a problem with anything else though... i even put my stock coil back on and it ran normal..lol but with accel, all it did was misfireOriginally Posted by jonarotz
