Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
air intake
Old Aug 8, 2008 | 09:29 PM
cjohn310's Avatar
Car: 1992 FIREBIRD
air intake
im looking to redo my air intake system on my 92 bird with a 305 tbi i know all about open elements and i just want tomake shur i lok at all my options before spending the money on one. i also have looked a spectrum and like that style set up but is that all for that type of set up.
Old Aug 9, 2008 | 09:13 AM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Re: air intake
no. Open Elements may allow more flow, but makes the engine take in hot air. You could get a functional cowl hood and then use an open element filter. That would probably be best. Or you can get a dual snorkle intake. These are rare and expensive so your best bet would be to make your own. Twice as much flow and cold air. Thats what i did on my LG4. Ill post a pic when i get a chance.
Old Aug 9, 2008 | 10:20 AM
cjohn310's Avatar
Car: 1992 FIREBIRD
Re: air intake
ya i thought about making my own but one proble im running in to is my tbi and hood space and it has to be tall enough to clear the the injectors but it cant hit the hood but if u or any one out there has a home made intake on the third gen let me know.
Old Aug 9, 2008 | 09:18 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Re: air intake
I have a home made intake. My car is carbed but i think your should fit fine. The stock TBI aircleaner can be customized to have two intakes. Shouldn't change the way it sits.
The intake after I made it
The intake on my car
Old Aug 9, 2008 | 10:27 PM
cjohn310's Avatar
Car: 1992 FIREBIRD
Re: air intake
ya i have heared of people runing two ram air systems on the tbi but were did you get the air box and parts and did you notice a difference?
Old Aug 10, 2008 | 09:08 AM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Re: air intake
the "airbox" is the one that came on the car. The passanger side snorkle i got at the junk yard along with the plumbing to the front of the hood. I cut a hole and brazed the snorkle on. Then i cut and flipped the front of the passenger side ram air duct so it was sorta oposite of the stock one. Epoxy can do wonders. Its either that or you can find a different ram air piece from a different old car. But i like them looking about the same.
And yes it is definetly makes a difference. Mostly when the engine is at high rpms. It is said to make a .5 difference in the quarter.
You need to make sure you have a high-flow filter though. I took out my air filter when i was racing and ran .3 better. It was a crappy purolator. Get like a k&n or something.
Old Aug 11, 2008 | 07:03 PM
84 maro's Avatar
Car: 84 Camaro Sports Coupe
Engine: Carb'd 5.7L 350 W/ Funct. SS Hood
Axle/Gears: Stock for now
Re: air intake
i say open element and ram it, i have the ss hood and im gonna fiberglass a scoop on the underside to ram it into an open element nice and cold
Old May 9, 2011 | 09:32 AM
dahluwalia's Avatar
Re: air intake
hey I,m thinking of making somthing simalar for my 82 carbed z28. seems like there should be good flow they.Do you think it works well?If I'm making it does anybody have any ideals to inprove it? or where to get materails and ideals.I thought about extending it beond or on top of the lights
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
