Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
heads, intake, headers.
Old Dec 15, 2008 | 03:40 PM
dalton992's Avatar
I just got a 91 camaro with a 305 tbi everything stock and i was wanting to put some aftermarket heads, intake, and headers on it. and i was wanting to know what you would suggest. i want about 300- 350 hp. so i guess let me know. thanks.
Old Dec 15, 2008 | 04:32 PM
1991355camaro's Avatar
Car: 1991 Camaro
Engine: 350 punched.30
Transmission: Had auto swap it 2 5 speed
Re: heads, intake, headers.
Look for somthing with at least 2.02/ intake and 1.90 exhaust for the heads. Edlebrock makes a good intake for tbi its called the perfomer I think i paid like 170.0 for it. I just pulled my 305 in my 91 rs and dumped in a 350 punch .30 over with intake hooker headers and rhs heads .500 lift comp cam full roller tb spacer still looking for a chip. O yea put a five speed in it 2 sucker won't hook till 4 gear. Anyway start there..Good luck P.S Really want to change out tthat stock cam to.
Old Dec 15, 2008 | 05:57 PM
bad88_milldawg's Avatar
Car: 1991 Hardtop RS
Engine: 406 Small block
Transmission: TH 350
Axle/Gears: custom fabbed 12 bolt posi, 4:11
Good point. I think If I was in your position id pull the 305 and swap in something alot bigger. but thats just me.
Old Dec 18, 2008 | 06:02 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Junior member, 1 post...
Welcome!!
Here your will find an incredible amount of expertise, as well as an amusing
assortment of gas-bags, so CAVEAT EMPTOR.
But remember, it's all FREE!
The 305/350 debate is endless, with successful practitioners on both sides.
But cost effectiveness weighs much heavier toward the 350.
My assumption is that by the very nature of the question, your experience
level is low. If not please don't be offended.
To that end, start with smaller scale mods than heads/cams, such as
the edelbrock manifold, and exhaust upgrades. These will get you into
the next step of tuning. By then, you'll have some experience on the
cost-per-go-faster factor.
Always good to have another 3g enthusiast aboard.
kk
Old Dec 18, 2008 | 07:11 PM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
From what I've seen Ported stock head Aftermarket Cam .Headers, High flowing Exhaust, better Intake, & tuning. You could get close to your goal.
I would stay away from 2.02" valves in the head on a 305. The intake valves will be shrouded. hurting the air flow. do a search on 305 tbi build ups.
Old Dec 20, 2008 | 12:13 AM
ljnowell's Avatar
Thats crazy talk. 1.90 exhaust valves? 2.02 intake on a 305? Do you know the bore diameter of the 305? Or valve guide spacing on SBC? Do some math and then post again.
Old Feb 7, 2009 | 10:50 AM
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
I came across this build up in Popular Hot Rodding a little while ago. Same ideas as always, but I've never heard of the heads they used mentioned on this site before. I think they come for about $450 as bare castings. But the article didn't mention any of problems with bolting them up or gasket thickness I've heard of with Vortec heads. Thoughts?
http://www.popularhotrodding.com/eng...cks/index.html
Jake_92RS
Jan 28, 2020 10:37 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
mdtoren
Aug 16, 2015 05:45 PM
