Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Hypertech vs. Fastchip vs. Jet
Old Dec 14, 2000 | 10:40 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I want to get a new chip for my '90 Iroc, TPI 305 5spd. I don't know what to get, Hypertech Thermomaster, Fastchip Stage 2, or Jet Stage 2. Hypertech seems to be the most popular, but people have also said they hate hypertech. Fastchip programs at all throttle positions, where as hypertech only at WOT. And Jet seems like a good chip too. I'm looking for people who have experienced any of these, and their reactions. Thanks for all the help.
'89 Camaro RS 6cyl. auto, don't know how much longer I'll have it.
'90 Iroc TPI 305, 5 spd (no mods...yet )
Old Dec 14, 2000 | 10:52 PM
Mike Harvey's Avatar
Well I just got the JET Chip Stage 2 and installed that yesterday and noticed a pretty big difference. This is the one thing to look for as well when you decide on a chip; is it a smog legal chip? Cause the JET's are. I really like it when I gun the accelerator that car really shows me more nuts. I'm very pleased and only paid $115 from Summit Racing for it. By the way Hypertech chips are pieces of junks. WHen my dad and I went to install the chip in my moms Blazer we had to go through 2 chips b/c the 1st 2 were defective and we said screw and went w/ the JET 6 pack and have been happy ever since. My thoughts
- Mike Harvey -
The '86 Firebird http://www.geocities.com/flash_point2002
Old Dec 15, 2000 | 02:38 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Nothing beats your own custom chip...especially one you burn yourself. Read Traxion's article on PROM Burning and check out ALL the links he provides.
Also, scope out the PROM Board and set you "Show Topics" to as old as possible (top right corner of the board) and start reading all posts from the oldest to most recent. Burning your own PROM is not quite as hard as you may think (mechanically), but it does involve a certain amount of experimentation to figure out what works and what doesn't.
Also, if you continue to mod your car, the equipment will quickly pay for itself and you'll be much wiser for it. It also will REALLY teach you a lot of about your car and engine. You will quickly learn "what is fact and what is fiction". I see many posts that contain a lot of myths/fiction about what is truly happening inside their motor. You'd be surprised how some relatively insignificant mods have a serious effect on your ECM (like changing gears with an automatic).
Lastly, imagine the personal satisfaction you will have when people ask you about your car and you say "And I burnt my own chip".
Old Dec 15, 2000 | 04:51 PM
MikeDwhoROCZImports's Avatar
I don't really think that being smog legal would be a problem, considering it takes less than 20 min to pull the chip out and throw your stock one back in.
Old Dec 17, 2000 | 02:04 PM
dude12387's Avatar
I have a jet in my trans am, and my friend has a hypertech in his camaro, and i think that the hypertech is way better. The jet doesnt do much in the way of shift points, but the hypertech does require a fan switch and a 165* thermostat. but id still go with hypertech
Old Dec 17, 2000 | 02:23 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Ive had all three chips and Ill give you the low-down on them. I now have a Fastchip custom chip that I think works the best of the three. I first had a hypertech chip and I thought it sucked. I dident notice anything and my speed limiter was still the same. Then I got a Jet stage 2 chip and noticed a better difference than the Hypertech plus the Jet chip moved my speed limiter from 115 to 130 mph. Just my .02
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.52/1.6 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, 3.23 rear gears, white face gagues, and NOS!
When I get back from Kosovo I will be installing these on-order items!
Old Dec 17, 2000 | 06:25 PM
need 4 speed's Avatar
I have a Hypertech chip and cant tell a diferance.I've even put the stock chip back in to compare the two,noticed no difrence.Waste of money if you ask me.Burn youre own chip, you'd be happier.
Old Dec 18, 2000 | 08:46 PM
89Formula350's Avatar
Any comments about the Performance Resource chips? I was hearing some good things about them...
89 Formula 350 WS6-BONE STOCK (not for long)
60FT-2.00
1/4 ET-14.25
1/4 MPH-96.07
69GTOby
Apr 18, 2016 02:34 PM
KO1
16
Oct 15, 2015 05:00 PM
3.8TransAM
Sep 17, 2015 02:16 PM
mackjar66
Sep 14, 2015 01:17 PM
