Why does the JET Air Foil fit in the rubber intake tube rather than bolt to the TB???
Subscribe
Dec 17, 2000 | 09:53 PM
Why does the JET Air Foil fit in the rubber intake tube rather than bolt to the TB, is there some sort of advantage to that?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Reply 0
Dec 17, 2000 | 11:12 PM
It doesn't fit in the throttle body? Thats strange...I don't think there is really an advantage to this...it may even be a disadvantage. I used to have the one made by holley and it was kinda horrible so I got the one from Comp Polymers which is kinda like the TPIS design and that works alot better.
Reply 0
Dec 18, 2000 | 01:05 PM
If its like mine it does fit in the TB. But there is a lip on it. The rubber duct work holds it in the TB.
Its easyer to install/remove, you dont have to remove the cover from the TB. One person I know of did have a problem keeping it in place. Ive never had a problem with mine though. It made for slightly better responce.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Reply 0
Dec 18, 2000 | 05:46 PM
Yea, it does lip into the TB, but its not like it bolts in there, it just sits up aganist it and is held in by the rubber hose thingy.
L98 TPI 350 (5.7L)
Reply 0
Dec 18, 2000 | 07:38 PM
Cause it's cheaply made compared to the others?
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Reply 0
Dec 18, 2000 | 10:21 PM
i just got the one from slp (slponline.com) it was 26.00 bolts to the throttle body and is the cheepest one i have found sofar (on special for christmas so hurry
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
Reply 0
Dec 19, 2000 | 01:39 PM
I have the SLP one too. $30 and works great.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Street legal with stock throttle body, runners,intake manifold,cam, and heads.
Reply 0
Dec 19, 2000 | 09:05 PM
Or... You could do what I did when I was still TPI. I drilled a small hole through the throttle body and the airfoil and used a screw to hold it in place.
Reply 0
Subscribe
