Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Voltage Stabilizer
Old Apr 20, 2009 | 08:42 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Voltage Stabilizer
was on the bay today and seen this
http://cgi.ebay.com/ebaymotors/Volta...1%7C240%3A1318
WTF is it and what does it really do......never seen or heard of such
i throwing a flag on it
THOUGHTS???
Old Apr 20, 2009 | 09:04 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Voltage Stabilizer
http://en.wikipedia.org/wiki/Voltage_regulator
Old Apr 20, 2009 | 09:18 PM
89RS_82Z's Avatar
Many simple DC power supplies regulate the voltage using a shunt regulator such as a zener diode, avalanche breakdown diode, or voltage regulator tube. Each of these devices begins conducting at a specified voltage and will conduct as much current as required to hold its terminal voltage to that specified voltage. The power supply is designed to only supply a maximum amount of current that is within the safe operating capability of the shunt regulating device (commonly, by using a series resistor). In shunt regulators, the voltage reference is also the regulating device.
If the stabilizer must provide more power, the shunt regulator output is only used to provide the standard voltage reference for the electronic device, known as the voltage stabilizer. The voltage stabilizer is the electronic device, able to deliver much larger currents on demand.
so its pretty much right???
our cars have internaly regulated alts so this is just some ebay junk???
Old Apr 20, 2009 | 09:29 PM
krisb410's Avatar
Just because you don't need it, doesn't mean it's
Old Apr 21, 2009 | 04:42 PM
89RS_82Z's Avatar
when its says camaro 89-09 in the decription it is
Old Apr 25, 2009 | 03:29 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
While I've never seen one this cheap (definitely worries me a bit), there is merit to this part for the stereo guys. If this unit does what it says its supposed to, it manages to eliminate dips and spikes in voltage. In an all out competition setting, a dip in voltage could cost you do to a drop in spl, etc. However, for the every day car driver, spend your money elsewhere.
As for the auction title, they're just trying to get the product seen in searches it normally wouldn't. Sneaky sneaky
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Elephantismo
Feb 13, 2019 12:51 AM
1992Z28!
Nov 19, 2015 07:33 AM
327IROC85
Sep 23, 2015 12:11 AM
roysatikas
Sep 22, 2015 08:15 PM
