Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
select the best Spark plug
Old Apr 30, 2009 | 02:20 AM
Artic-Trans am's Avatar
Car: 87 TA
Engine: 350 modifyed Stelth Ram
Transmission: 350 rew lock up
Axle/Gears: 9"
hi
I have got a new engine that I will go in my car now.
but I have no recomandation what spark plug I should use.
this is the engine description:
3.48 stroke crank
hi flow heads 2,02/1.6 valves
roller rockers 1,6 ratio
cam lift .574 INT .593 EXH togeter with the 1,6 rockers
flat top pistons
10.5:1 comp
I guess this enginge with this comp will be a little hotter than a stock 350 engine.
so my thought about the spark plug is, I need a little colder than the stock NGK FR5 so I did some search on the NGK page and ended with this choice:
BCPR6ES
PFR6B-9
BKR7E
BCPR7ET
all NGK plugs
The higer number = colder plug
Well then there is this problem together with this engine. I am going to use a HOLLEY stelth ram. That will give me some tuning, when stat up this enging fist time. When tuning my enginge I always start with a rich mixture and lean this too a good mixture.
So will I have problems with fouling my plugs, using a cold spark plug when tuning?
there is allot off experts on this forum, so I ask you! Is my choice off plugs the correct thought?
Old Apr 30, 2009 | 02:43 AM
jared07's Avatar
Re: select the best Spark plug
the only thing i can tell you is way to pick the best manuf of plugs...NGK all the way!
Old Apr 30, 2009 | 03:19 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Hopefully you actually know what heads you have, beyond just "high flow" heads.
Old Apr 30, 2009 | 03:27 AM
Car: 87 TA
Axle/Gears: 9"
yea I know. but if i say what type I have there will be a big discussion about how bad they are.
don't want that!!!
Jegs recomand to use the FR5 plug on this head. but that is with normal some around 9 to 1 comp.
Old Apr 30, 2009 | 03:54 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
i just use the ACCEL header plugs, they work damn well and i aint had a bit of a problem out of them.
Old Apr 30, 2009 | 04:12 PM
jared07's Avatar
i just looked at the accel's 0576 might be the right ones...
dont quote me though
jegs offers these plugs in most of their ignition kits, does anyone know about the quality of these plugs?
Old Apr 30, 2009 | 06:00 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
the best spark plug is the one thats gapped correctly
Old Apr 30, 2009 | 06:03 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
there great plugs, i have them in my 1987 305 TPI and it runs great. My dad also runs the same plugs in his carbed 383 with plenty of power and that have performed performance and reliabilty wise better then any other plugs we have tried. Some cars just dont like expensive platinum or iridium plugs.
Old Apr 30, 2009 | 06:56 PM
RedLava's Avatar
Car: 86 z28
I personally like bosch platinums.
I have had a bad experience with champions.
Old Apr 30, 2009 | 07:40 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I'd use AC R43TS
Old May 1, 2009 | 04:25 PM
Car: 87 TA
Axle/Gears: 9"
so just the normal temp range!!!
I did use the AC plugs before, and I was not verry happy with them. Had some problems when tuning.
when adding to much fuel, they did not burn clean, some people told me then to change into NGK or Champion...
but that was another engine with less comp.
Old May 2, 2009 | 11:23 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
This morning, I saw the Horsepower TV guys showed on a Dyno that the Diamond Fire E3 plugs gave one of thier engiens an 8 hp increase over regular plugs.... I spent so much on headers and exhaust and got about double that...
Raf
Old May 3, 2009 | 07:22 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Raf
The last time I looked at an E3 HP graph, they did provide more HP but it was in the upper rpm range. They actually (according to the graph) lost some power down low.
I'm not saying they are bad. Just make sure you check out the graphs and know your power range before you buy. Just my 2 cents.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
