Summit 383 Blocks
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: Summit 383 Blocks
Piston manufacturing these days is spot on.
If a piston has a minimum clearance, (and they all do) the clearance is accounted for in the finished piston size.
For example, if a 4.030 piston has a minimum clearance requirement of .0015, the piston will measure 4.0285.
If the machinist determines that the engine needs more than the minimum clearance, he can overhone the cylinder accordingly.
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Looks like my piston sat .024" in the bore.... as best that I could tell. (maybe .023")
I used a dial indicator to make sure that #1 piston was @TDC and a feeler gauge under the straight edge of a steel square to measure.
That's with SRP Forged Flat Top Pistons PN-138093
and Eagle 6" H-Beam Rods PN-CRS6000B3D
3.75" Eagle Crank
3.75" Eagle Crank
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
thats one of the issues i will have when building mine for proper quench, my engine will be boosted so i must account for proper ring gap and quench to insure the best overall combustion possible.
doing as you did is the absoulute best way to read tdc, once the dial starts going the opposite way you know you have passed tdc, as for feeler gauges straight edges, i have always been scared of straight edges for a long time, i mean how do we know they are absoulutly straight? what if they got damaged in shipping transit?
to me thats the only way to go, the dial indicator, thats how you setup a adjustible timing pointer also. i am shooting for a .040 to .045 quench so i have to measure then find the head gaskets with the exact thickness to achieve that quench.
good luck man the devil is in the details..
p.s congrats!
p.s congrats!
Car: 1982 Z28
Engine: 383
Transmission: TCI TH350
Axle/Gears: 3.23 Posi
I am putting one of the summit 383 blocks together and all the clearances have been spot on. Ring end gap, mains, endplay, and cylinder bores all checked out good. I have attached a few pics of the block.
All I had to do was wipe a little surface rust out of the cylinders and assemble.
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Might be ok for street use or a daily driver, but I sure wouldn't use a Summit block in a high performance engine.... Curious to see what piston to wall clearances are with these blocks. Maybe I'm just fussy or something, but I still have my blocks honed to final fit and 0 deck the block--hard to get CR's correct if it's not zero decked...
This summer will be the 4th season on a Dart Little M block, this winter's teardown was just like the last 3 years. Block is still in great condition. For a street/strip build the Dart SHP and SHP Pro blocks IMO are a cost effective solution.
Car: '82 Camaro
Engine: 383
How far down in the cylinder are the piston tops on your Sumitt block? What rings did you use, and what did you set the end gap at? Should be a nice unit for the street!!!!
Car: 1982 Z28
Engine: 383
I used Mahle moly rings that came with my eagle reciprocating kit. The rings all checked out right around .016-.018 end gap.
The pistons sat .022-.024 below the deck. For what I spent on the block (upper ends of my spending limit) I feel it was worth the money.
Car: '82 Camaro
Engine: 383
Do you recall the compression height on the pistons? I'd like to run it through the CR calculator and see where static and dynamic compression comes in at.. A nicely machined block like yours, even with an extra $100.00 or so for zero decking would have to be rated as one heck of a good deal!!!
Thanks for answering my questions!!!
Dave
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
http://www.summitracing.com/parts/SUM-150100/
Camshaft bearings line honed to standard: 1.8702” - 1.8710”
Mains, line honed: 2.6408” - 2.6418”
Cylinders finished honed: 4.0300” - 4.0308”Minimum deck height: 9.013
Car: 1982 Z28
Engine: 383
I am not sure what my compression height is on the pistons. Here is a link to the assembly I bought.
http://www.summitracing.com/parts/ESP-B13405L03053/
All it really says about the pistons is :
Piston MaterialHypereutectic aluminumPiston StyleFlat top, with two valve reliefsPiston Head Volume (cc)+5.00cc
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Im convinced the high nickel thing is a myth. I've never seen any proof at all. It's just always what someone heard from someone. Smokey Yunick probably farted somethign to that nature out of his armpit and it became gospel... Even if it is high in nickel, I see no scientific evidence that that is a good thing.
just sayin
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
Thanks jersyboyy, couldn't have said it better myself. Another example where high nickel content makes a difference is with the Cadillac blocks - they wear extremely well and this has been documented many times that the reason is the high nickel content of the cast iron.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Alot of blocks were higher nickel 010 and 020 (10% more and 20% more nickel) and pick up a book or search online instead of just trying to sound smart...scientific proof is everywhere about how nickel makes metals we use each day stronger, less likely to rust, resist more heat.
just sayin
just sayin
Car: 1982 Z28
Engine: 383
I wanted to add one more pic to show how they notch the block to accommodate the longer stroke. I outlined the notches.
Engine: 383 Carb
Transmission: 4L60
The oil pan rail often requires notching as shown, but sometimes the bottoms of the cylinder bores do as well.
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Engine: S/B
BTW AC I didnt see anywhere in this thread if you have been driving it and/or if it has had any issues or still happy with it?
Car: '82 Camaro
Engine: 383
Car: 1989 T-Top GTA
Since were all rebuilding engines here, or at least thinking about it... I thought that I would post a question...
First off does anybody have John Lingenfelter's book on Modifying small block Chevy engines?
http://www.amazon.com/John-Lingenfel.../dp/155788238X
On page 145 (in the Engine Blueprinting section) he describes how to put a 1/2 plug in one of the oil passages under the rear main cap to prevent an internal oil leak...
It seems that they are original from the factory, but get taken out during the cleaning process. He states that without it you will lose as much as 20 lbs oil pressure...
I never knew about this with the first engine rebuild that I did (not the GTA).... and it always had lower oil pressure than it should have....
Is anyone else doing this?
Car: 1989 T-Top GTA
Check out the picture here....
Didn't wanna hijack!!!
Maybe this will help all the backyard engine builders out there....
https://www.thirdgen.org/forums/tech...ml#post4896250
Engine: 383 Carb
Transmission: 4L60
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
So do the 383 Summit blocks have this plug missing or is it installed?
Car: 1989 T-Top GTA
The Summit 383 blocks don't have them..., but neither did my first rebuild engine that I picked up from a machine shop...
They have frost plugs installed on the outside of the block and Cam bearings, dowels etc but no plugs on the rear main....
Box of TEN 1/2" plugs cost me $2.oo
Thought I would let ya know....
Quick question though,
if your bypassing the filter does anything get filtered at all?
Car: 1989 T-Top GTA
Sorry guys but I was totally mistaken!!!
Upon further inspection, The Summit 383 Block "DOES HAVE THE PLUG"
I took the crank out of the block today to plastiguage the bearings and saw the plug further into the bore than I initially expected it to be...
Anyone need a box of 10 plugs....?
Car: 1982 Z28
Engine: 383
lol I was holding my breath on that one. I installed my motor already and thought I left the plug out. Glad you were able to confirm it was in there!!
I didn't want to have to pull it back out when it only had 15 miles on it.
New2Chevy
Sep 28, 2015 12:35 AM
RyanJB
Sep 14, 2015 03:39 PM
Andrew Prakash
Sep 8, 2015 11:48 AM
