Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
do i have the right combination for my 305 TPI
Old Dec 24, 2000 | 06:01 PM
vortech305's Avatar
whats up,
I have the following lists to my combination. I had the 305 bored over 30 forged parts all around instead i went with an 88 corvett aluminnum heads ported and polished comp cams alluminum roller rocker arms and accel cam part # 74211 ported the plennum cleaned and flowtested the stock 19lb injectors edelbrock intake manifold with SLP runners and BBK 52 throttle bodie i had the stock distributor with a hypertech coil and MSD 8.5 mm wires bosch plugs edelbrock headers catco catalitic converter and a 3 inch flowmaster exhaust new fuel pump and plan on getting a regulator. the motor is currently on a stand and the exhaust system is in my garage i plan on putting it in in febuary is my combination right i want full emissions and I belive its an 88 motor with mass air flow(check history site)i know it was long but hopefully any of u guys can help thanks
vortech305
Old Dec 26, 2000 | 06:01 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Sounds like a good combo. You should be able to get close to the 1hp/cu in mark.
D&Z Performance
"Putting Power to the Pavement"
Old Dec 28, 2000 | 10:18 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I think that the vette heads might mess up your compression ratio. I beleive that 305 heads are 58cc and 350 heads are 64cc? But other than that, it looks like a good motor.
Old Dec 28, 2000 | 02:15 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The L98 Corvette heads are 58cc's. The L98 F-Body heads are 64cc's.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
