b&m megashifter second cable location????
Car: 91 camaro RS
I just put in the shifter and i cant seem to find out where the column/ key cable attaches to. I cant find a thread about it and i dont want to call support yet. Any help would be HELPFULL. And if you can provide pics of the installiation i would greatly appreaciate it.
or if you now of a thread.
thanks rich
thanks rich
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: b&m megashifter second cable location????
You don't connect it. Sits in there wired in the park position.
"The Park lock cable must be wired in the Park position (fully in) so that the steering column lock will work and will allow the key to be removed. The cable should also be secured inside of the console out of the way. After wiring the cable in this position check to see that the steering column lock works correctly, and that you can remove the key. WARNING: With the interlock disabled in this manner it is possible to lock the steering column at any time, so be careful not to turn the key to the “LOCK” position while the car is moving"
Engine: 350 - 305 801 Heads
Axle/Gears: Stock
Dam Thats what it says in the instructions too but I must be stupid. Been looking for this answer for a long time lol. Finally the "light goes on! Dugh!!!!
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Alicat.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
wigmobile
Feb 26, 2025 02:56 PM
topteam54
Oct 6, 2015 12:21 AM
