Global West Wonder Bar
Car: 89 RS,02 WS6 M6,08 GMC Sierra SLE
Engine: ZZ4HCI, LS1, LY5
Transmission: T5/T56/4L60E
Axle/Gears: 323,342,373
Just thought i would put this up to save everyone some time and money in the long run. Bought the Global West wonder bar and was extremely disappointed. Got it from Summit for 40 dollars and it wouldnt even mount do to not fitting between the front frame rails. I flipped it and tried both ways and still nothing. Basically looks like bad quality to me. Just made a bar with a mounting plate and put some paint on it. Sure i could have made it fit with some grinding but just seemed wrong to spend money on something i have to make fit. I ended up going with the UMI wonder bar and installed without a problem. Great product and great quality.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Global West Wonder Bar
Mine fit perfectly out of the box.JamesC
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Wish I could have saved you some money.
I installed a global west wander bar on my 91 RS. Looked at close when I got it and right away say the tabs were not perfectly aligned on the bar. If you set one on the edge of a flat table the other side would stick up a small amount.
Went to install it, could not go on without some holes filed. Measures and swa they were off a small amount.
Makes me wonder about the quality of the rest of their parts. (but not much because I wont buy their parts again).
Luckily my 89 already had a TDS when I bought the car so the GW hangs in my garage.
Yea i hear ya bro, the quality is terrible. It literally looks like they took a pipe, made some rough measurements and put some mounting brackets on it. For me the holes lined up but there was too much material on the pipe to fit between the front frame rails. Like i said i could have ground it down but i didnt want to put a band-aid fix on a new paid for product.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
You read Camaro Performers Magazine and they are always putting some GW parts on a car. I suppose though if they gave me some parts for free or close to it I would not say anthing bad about them as well.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Too bad about the Global West stuff. Did you return to Summit for a refund?
Car: 87 GTA
Did you put the UMI one next to the GW one, before putting the UMI one on, and see where the problem was with the GW one?
yea summit let me return it without any issues. Well without putting them next to each other i just knew the UMI one would work because the ends are tapered versus the GW one was just a bar from one bracket end to the other. The UMI bar had brackets on the ends and then the bar started between of the 2 mounting plates pretty much like the stock ones that came on some thirdgens.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Car: 89 IROC
When it comes to four letter words...."FREE" is one that everyone likes.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Well you know how they say stuff like "40 is the new 30".
Free is the new "that cost too much i need it for less than free"
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
love the UMI bar ipurchased woulda liked some sorta factory stamp or a sticker for my $65 bar but it still looks great and NO issues
Car: 87 GTA
you might want to check the packaging yours came in, mine came with a small decal in the instructions to put on after.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Please "stack" large photos so we don't have to deal with a stretched page.
Thanks, for fixing that, much easier to read, view, and reply now.
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Sux about the Global West bar... I also have a UMI wonder-bar and agree that the quality and fitment are outstanding.
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
I love my UMI bar, perfect no issue product. Same with my SFI's
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
Hey guys are the aftermarket bars any better as far as strength or somehting compared to the factory ones?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Engine: 40 over 350
Transmission: 86 T5
Thats interesting, so I wonder if there are guys out there who actually have factory ones but then still replace them with aftermarket. I spose. Do all third gens have the holes for where they go, or do they need to be drilled?
. Since the bar goes under the sway bar installation of the proper bar isn't an issue.JamesC
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
Global West wonder bar fit perfectly on my 1988 GTA (I guess the GTA didn't come with this bar from the factory?). I also purchased and used the rear control arms and panhard bar - fit perfectly and very high quality.
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
I have gw sfc for stock exhaust and I dunno if it was the sag in my car but the angle that it mounted to the driver side frame was off but I just built it up and its pretty close now but I like the shape of it and was not a huge deal but that's just me
darwinprice
17
Oct 11, 2015 11:51 PM
