Need help picking heads???
Car: 1991 Camaro Rs
Engine: 360 ci in progress
Transmission: in progress
Axle/Gears: 4/11 gears
I have a 350 bored 60 over so a 360 ci, an im trying to pick some heads any suggestions???? thanks
Re: Need help picking heads???
What are your power goals?
Track car, or do you intend on daily driving, or at least driving every weekend?
From what I've researched, Edelbrock Performer RPM aluminum heads seem to be an all around good head. 64cc chambers for a slight bump in compression, they're only 185's so you won't have to rev the crank out of the mains just to make some power.
What are you doing as far as induction? I'm assuming naturally aspirated, but carbed or fuel injected? What sort of carb or fuel injection setup? What cam are you running? Intake manifold? Are you sticking with the 4.11:1 gears mentioned?
Lots of variables to make the right decision.
ambainb
Apr 25, 2016 09:21 PM
