Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Crate engines?
Old Oct 7, 2011 | 09:13 AM
mightydunk's Avatar
Car: 1990 Iroc-z Camaro
Engine: 5.7L
Transmission: Automatic
Crate engines?
I plan on swapping my 305 C.I out with a bigger crate engine and saw some great 383 C.I engines with 470 crank HP for around $4,300. i cant seem to find any better deal for a new crate engine with a warranty any suggestions?
Old Oct 7, 2011 | 10:04 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Re: Crate engines?
A LOT more bang for your buck if you build it. Just grab a friend that has done it before and have fun. It feels great knowing you put together the beast running under your hood.
Old Oct 7, 2011 | 12:39 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Crate engines?
plan on doing any other upgrades like exhaust and rear end and subframe connectors too? also are you going to carb it or run stock FI?
Old Oct 7, 2011 | 01:51 PM
Notalent's Avatar
Car: 71' Chevelle
Engine: 496ci 675HP Streetable!
Transmission: TH400 3500 Stall 9.5" Converter
Re: Crate engines?
Let me know what your looking for and I can help you. Are you swapping to a carb setup? Power Brakes?
Brandon
www.highperformanceengines.com
Old Oct 7, 2011 | 02:12 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Crate engines?
You can save a lot of money if you do it yourself but you'll need to do research to make a really good combo. And if you buy a crate you'll usually get a warranty.
Balance it out
Crate:
Higher cost
No time invested in parts research
Warranty and implicit guarantee of parts condition
DIY:
Lower cost
Research/time needed
risk of junk parts, failure etc
But the cost of having a machine shop assemble you an engine usually isnt extremely high and can still be cost competitive compared to a crate but there's a lot of variance in quality and expertise if you let them supply parts for you. You'll still usually be better off putting the time into research. I like my machine shop a lot, good guys up there, but they wont warranty a motor they build because there's just too many unknowns when you throw together a lot of parts from unknown origins, even new parts can fail.
Really to me the biggest advantage of a crate is a warranty. The biggest disadvatnage of DIY'ing it is when you spend all your time piecemealing it together and gettign into one big lump and dropping it in the car, and then your block cracks or your heads crack or you lose a cam lobe etc etc.
Old Oct 7, 2011 | 03:16 PM
mightydunk's Avatar
Engine: 5.7L
Re: Crate engines?
i would do that but i mean a guy i know took over a year to put an ls1 in one of his cars and i want to try and keep it simple but get a nice kick in the end
Old Oct 7, 2011 | 03:22 PM
mightydunk's Avatar
Engine: 5.7L
Re: Crate engines?
probably subframe connectors and deffonightly a carb my tpi 305 fuel preassure is at like 25 then drops to 20 when it gets warm so im gonna take the throttle body out and put a edelbrock carb on to fix that issue so ill have a carb setup already
Old Oct 7, 2011 | 03:25 PM
mightydunk's Avatar
Engine: 5.7L
Re: Crate engines?
yeah im swapping to a carb setup and what do you mean by power brakes? think i already got em?
Old Oct 7, 2011 | 03:39 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: Crate engines?
LOOK NO FURTHER.
I know of a site where you can get a remanufactured 350hp Chevy Gen I 350 with 400lbs tq, COMPLETE ENGINE with a 12,000mi 12 month warranty (or a 36,000mi 36 month warranty for $250 more). It’s called www.cmengines.com.
383 Stoker for $500 more (425hp 500+tq). They have 450 and 500hp Versions. The 450hp version runs $4500 witht the 12,000mi warrenty. The 500 is like 6 grand so I'd go with the 450. Once again, these are COMPLETE engines. You can get just the block or whatever too, but the complete engine is only slightly more expensive one worth the money to have it done right and completed with a warrenty.
Anyway, if you’re curious, look at street performance engines.
People who have done business with them here have nothing but positive things to say about them.
Old Oct 7, 2011 | 03:51 PM
mightydunk's Avatar
Engine: 5.7L
Re: Crate engines?
their prices are pretty good a 550HP 496 C.I for $5800
Old Oct 7, 2011 | 04:01 PM
Car: 1992 Camaro RS
Re: Crate engines?
Even when just looking for some info I had some positive exeriance. Email them and they'll give you all the information you want on any engine and more. The engines they build are very reliable and like I said, everyone I know who has done business with them loves em. One guy here bought a 383 stroker from them like 10 years ago or something like that, and it still runs perfectly to this day. And yes. Excellent Prices.
Old Oct 7, 2011 | 04:08 PM
Car: 1992 Camaro RS
Re: Crate engines?
You should use the search here. There are a few results.
Old Oct 7, 2011 | 05:36 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Crate engines?
Here's a link to "Chevy Performance" were they have a few nice engines to chose from and I looked through there site and they do offer a warranty.=
http://www.gmperformanceparts.com/Parts/showcase.jsp
Scroll down one page on this link and it gives you a break down of their warranties =http://www.gmperformanceparts.com/_r...arranty_4C.pdf
Old Oct 7, 2011 | 06:19 PM
Car: 1992 Camaro RS
Re: Crate engines?
I don't like the pricing. New ZZ4 with 350hp and 400lbs tq from them is about $5,300. A Gen I Chevy 350 (thats pretty much the same) with the same Dino results Sells for $2,995 at www.cmengines.com.
Old Oct 10, 2011 | 02:18 PM
Notalent's Avatar
Car: 71' Chevelle
Re: Crate engines?
In the power range you are looking, you need a large camshaft....larger cam = less vacuum which means no brakes.
Make sure you see what parts are in these engines....lots of companies are using cheap chinese junk for parts... Low price doesnt mean better.
Old Oct 10, 2011 | 11:43 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Re: Crate engines?
I think crate motors are the way to go unless you have the skills, the talent, and the tools to fabricate a quality one on your own. With a GMPP crate motor for example, you have a part number for every piece that can be cross referenced and you know it will all work together. In 1996 I put a GMPP crate 5.7 in my Camaro and it was the best decision I've ever made.
Old Oct 11, 2011 | 12:13 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: Crate engines?
If you're looking for a GMPP crate engine we have them available on our site for much less that most competitors. You can find them through the link below. We have Gen I engines as well as LS engines available.
http://thirdgenranch.com/-strse-Engi...Categories.bok
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
