Shifter cable
Subscribe
Nov 3, 2011 | 07:19 PM
My oem cable for some reason broke after my engine swap, and i bought a replacement from autozone. I would expect a replacement part to do its job but it seems like all the aftermarket shifter cables dont work properly. Mine will shift down but not back up, so if im in drive it wont shift back into park. Anyone know of a replacement that works? If i can temember reading, they discontinued then at the dealer.
Reply 0
Nov 3, 2011 | 09:39 PM
Re: Shifter cable
i got mine from autozone and its been working with no problem, got it a few months ago
Reply 0
Nov 3, 2011 | 11:00 PM
Re: Shifter cable
there have been numerous problems with aftermarket ones. I have a good used factory one that came out of my car when I installed the BM megashifter. You can PM me if interested in purchasing it.
Reply 0
Nov 4, 2011 | 07:00 PM
Re: Shifter cable
I have been having issues with my after market one i am going to Pick n Pull to get a couple and see why the oe is so much better.
Reply 0
Nov 5, 2011 | 06:55 PM
Re: Shifter cable
i just replaced mine last month i got it from napa and i havent had any problems.
Reply 0
Nov 6, 2011 | 02:36 AM
Re: Shifter cable
I had similar problems but assumed it was due to the shift linkage that goes from the column to the trans. Because the Camaro has an in-cabin cable to do the same thing, I assumed it would have fewer problems with shift cables. Good luck.
Reply 0
Subscribe
