I have a 350 TPI with AFR 190 heads and was wondering what cam you guys thnk would be the best.
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:27 Times in 23 Posts
There is no "best cam". It all depends on the rest of your combo. Headers? Exhaust? Automatic? Stall Converter? Suspension? Daily driver? Give us some more info.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
also headers, 2000 rpm converter, and the usual mods for the best performance, i just wanted an overall opinion on the favorite cams
Kevin91Z
close
- Join DateJul 1999
See the camshaft tech article on this site for some good suggestions. For those AFR heads, I think the LPE219 cam would be great, or the LT4 HOT cam. I think you'll need a higher stall converter than 2000 tho, more like 2400-2800. And SLP's 1 3/4" headers.
The LT4 Hot Cam sounds like a good choice for your car. Its specs are 218/228 with .492" lift with the 1.5 RRs. If you want a little more, and don't mind sacrifising idle, the more radical of the 2 SLP cams from Summit is a good choice. Its specs are 224/230 with .502"/.510" lift with the 1.5RRs. The SLP cam is about 2 times the cost of the LT4 Cam though.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: LT4 Hot Cam, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Fully Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
