Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Gear drive
Old Apr 12, 2013 | 01:24 AM
1200hdbrad's Avatar
Car: 88 IROC Z 305tpi, 88 GTA 350tpi
Gear drive
I am debating on putting a timing gear drive in. Any reason I should not? And also how to tell the difference between a gear drive for a roller style cam. Any help would be appreciated. Thanks
Old Apr 12, 2013 | 09:39 AM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Re: Gear drive
I think this is posted in the wrong place. I dont think you can run a gear drive for a tpi. The noise makes the ecm think there is knock.
Old Apr 12, 2013 | 12:20 PM
1200hdbrad's Avatar
Re: Gear drive
I guess I left out an important tid bit... I just did a carb swap. I just don't know too much about gear drives and I thought I would ask.
Old Apr 12, 2013 | 01:27 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Gear drive
If you want a noisy one for the cool sound go for it.
Otherwise I would stick with a good timing chain.
Some say gear drives are bad, may transfer harmonics to valvetrain.
I have not seen any serious engine builders use gear drives in a long time.
Old Apr 12, 2013 | 02:37 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Gear drive
The noise is cool at first....for about 5 minutes. You'll learn to hate it. At least I did.
YMMV
Old Apr 12, 2013 | 02:52 PM
Car: 1971 Camaro
Engine: 427
Re: Gear drive
YMMV
Yep, our joke was always, he must have a gear drive or a bearing going out in his power steering pump.
Old Apr 12, 2013 | 03:28 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: Gear drive
If you like less HP get one.
Old Apr 12, 2013 | 06:13 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
Re: Gear drive
if you're running a solid roller lifter mega-lift and duration cam, I use them, but other wise, no, not to "just use one"
Old Apr 12, 2013 | 09:15 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Gear drive
I use. them. even with EFI. i use the Quiet ones. you dont hear them.
and i have my ecm set up to retard 0.0.. I always used Pete Jackson. out of biss now. part # 327-C.
you can get good ones still.just get the Quiet ones. yes i also run full mech roller cams as well. small ones in the 254 dur at 50 and just under 620 lift.
good street cams.
dont buy into that nonsense about harmonics. with a 1/4 car/eng.
if ya do..go get a belt drive..and let the belt fail...and see how ya like that
just me I like them...the last one still looked new even after 6 years of beating on it.. the only thing i wanted to replace was the cam button.
and thats cuz i wanted to...just me. a timng chain be a bit more. and not 100% after 6 years of drag racing...but with chains ya just toss them in the trash every few years anyway..
after all the V1 T Trim. Makes the same sound as a cheap gear drive..
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
