anyone know part # for tranny gear to make my speedo read right with 373 rearend
tired of speedo being off i had 273 gears now ive got 373 i have a 92 RS with 700r4 and 16"wheels with 245 50 16 tires anyone know gm part #? and how much they are thanks
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
3" exhuast cutout
2000 tci stall
If you had 273's you have to change drive and driven gears(pita). The list of numbers is in the Faq I believe.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
Wrong forum. Check the tranny/drivetrain forum. Its a 15 tooth and a 45 tooth.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
only problem, I belive they are discontinued. You might check though.
Jeremy
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's
when it warms up Edelbrock STB maybe springs
Jeremy
92 Z conv
5-spd B&M shifter
Car: Death Mobile
Engine: 666 c.i.
I think only the cable driven version is discontinue. The driven gear (45) for electronic speedos were still available last year.
Worst case scenerio, you can always contact TPIS. They will have it as they charge triple the price.
hectre13
12-11-2023 08:14 AM
