Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Ed Quay
Old Dec 3, 2013 | 06:47 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Ed Quay
Here is an email that I sent them regarding the headers I bought from them 2 weeks ago, they never replied. I paid 850.00 for the headers, I expected some challenges, but I would have been better to buy a header flange kit and tubes and make them myself, or spend the extra 400.00 and buy lemon stainless steel headers
I bought a set of header for my 86 Camaro with a big blockand just want to tell you how poorly they fit. I used your custom order sheetand talked to one of reps when I ordered them. On the passenger side, thecylinder 2 tube had to be cut, was hitting the oil pan and there was no way youcould get a starter in, I have the MSD mini starter, collector was hitting subframe. Drivers side, all tubes had to be cut, collector was hitting floor,could not even bolt on to motor because collector was hitting frame, also the header was hitting the block . I have to use remote oil filter because thereis no way you can get an oil filter out, it would have been just as easy tobuild a set myself. I was really surprised with the poor fitment of theseheaders, I was expecting a lot more with the name Ed Quay on them. Headers even came with a couple dents in themwhen I received them, but they were minor.
Old Dec 3, 2013 | 10:30 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Ed Quay
I have EQ's for my sbc in my car.
I had to change to solid motor mounts and cut the ears off of the trans to make mine fit. Other than that they were awesome.
I would phone them rather than an email if you have a problem.
Old Dec 4, 2013 | 12:36 AM
572_Rat's Avatar
Re: Ed Quay
I wish mine had been that easy, I have Quays solid mounts, car is at extreme, they have 18 hours just making headers fit
Old Dec 14, 2013 | 02:49 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Ed Quay
Huh.
When my car had a BBC in it, I got rid of the hookers, and got a set of 2 1/4" Ed Quays. They fit like a glove.
Of course I had a standard deck height BBC. Is your a tall deck?
Old Dec 15, 2013 | 12:42 PM
572_Rat's Avatar
Re: Ed Quay
Standard deck block, maybe mine where built on a Friday or Monday, who knows, I will post the pictures of all the modifications they had to make once I pickup the car
Old Dec 15, 2013 | 12:46 PM
Car: 1971 Camaro
Engine: 427
Re: Ed Quay
You got a stroked 502?
Old Dec 15, 2013 | 07:13 PM
572_Rat's Avatar
Re: Ed Quay
Dart big M block 9.8 deck height, 4.60 bore x 4.25 stroke = 565ci
Old Dec 16, 2013 | 12:40 PM
camaroracer21's Avatar
Car: 1983 Camaro
Engine: 358 SBC
Transmission: TH350
Axle/Gears: 9" Ford 4.56s
Re: Ed Quay
I am surpised to read these posts about a bad product from EQ. I bought the EQ master cylinder kit a few months ago. They modified the pedal as well. Was completed in about 2 weeks. I mounted it on the firewall and it was a perfect fit. Quay used a strange master cylinder so it is a good product. I have yet to test the brakes as I am still in the building stages of the project but I have no complaints about my EQ product so far.
Old Dec 16, 2013 | 10:22 PM
572_Rat's Avatar
Re: Ed Quay
Here is some pictures of the mods they had to do to get the headers to fit
Old Dec 17, 2013 | 06:07 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Ed Quay
And the additional cost was...? That looks like a LOT of money in backtracking..
Old Dec 17, 2013 | 10:25 AM
572_Rat's Avatar
Re: Ed Quay
18 hours at 92.00 and hour, now they are not going to charge me their full going rate, because he felt sorry for me. What pisses me off the most is they did not even respond to the emails I have sent them, called and they said that they would get back to me, never heard from them again
Old Dec 25, 2013 | 07:48 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ed Quay
Why did you pay a shop to install them?
-- Joe
Old Dec 25, 2013 | 10:35 AM
LidyGraphics's Avatar
Re: Ed Quay
why not call them before cutting them up. maybe they sent the wrong ones.
Old Dec 26, 2013 | 03:58 PM
572_Rat's Avatar
Re: Ed Quay
-- Joe
Because they did not fit and I don't weld, and they were doing the rest of the exhaust
Old Dec 26, 2013 | 03:59 PM
572_Rat's Avatar
Re: Ed Quay
Read the above posts
Chad Speier
Sep 24, 2015 12:32 PM
cj599
Aug 4, 2015 09:09 AM
Deimos140
May 9, 2012 08:22 PM
Camaroman
Aug 20, 2010 08:44 AM
HDon22s
Feb 18, 2009 06:39 AM
